Belly Pan Noise
prp1851
Posted 2015-06-20 11:34 AM (#172848)
Subject: Belly Pan Noise
Concord, NC
This topic/issue may have already been discussed, if so please forgive me. I have a 13 VV and I have a squeaking noise coming from the belly pan. It's really noticeable around 1500-2300 rpm. I've removed all the screws from the front tip overs and the belly pan, and put lock-tight on hoping that would stop it, but it hasn't. Any suggestions would be greatly appreciated-thanks in advance for you help!
Posted 2015-06-20 5:51 PM (#172852 - in reply to #172848)
Subject: Re: Belly Pan Noise
maybe its the belt and not the pan.
prp1851
Posted 2015-06-20 7:47 PM (#172854 - in reply to #172848)
Concord, NC
It could be-thank you...I'll check it out.
cw1115
Posted 2015-06-21 4:51 PM (#172865 - in reply to #172848)
Ruskin, Fl
I had an extremely annoying squeak coming from under my 2013. It was the battery mount. Get under there and try to wiggle your battery and see if you hear a squeak. At certain RPMs it almost sounded like a belt squeal. I had to put a piece of rubber between the battery in the bracket to make it stop.
prp1851
Posted 2015-06-21 6:38 PM (#172867 - in reply to #172848)
Concord, NC
That sounds like where it's coming from. When I tap on the bottom of the pan. It sounds like it's coming from the battery tray. I wasn't sure if it was the pan rubbing the tray or what, but thank you for suggestion, I'll definitely check into it!
ljurgens
Posted 2015-06-22 6:13 AM (#172876 - in reply to #172848)
West Salem, WI United States
I have that same squeak. There is a bolt at the front lower part of the battery tray. I think the bolt is to long. I had put some adhesive foam in there and that took care of it for a while, now I think the bolt has worn through the foam and its starting to squeak a bit again. Might try a shorter bolt, but that will probably require removing a panel or two.
cw1115
Posted 2015-06-22 9:14 AM (#172883 - in reply to #172848)
Ruskin, Fl
I took the bolt out and but a piece of rubber between the battery and the bracket. I ended up using a rubber squeegee for window tinting. LOL it works perfect.
Posted 2015-06-22 10:25 AM (#172885 - in reply to #172848)
this year.. i had a noise something like what you are talking about.. i thought it was under the windshield... here.. it was UNDER the bike.. under the tip overs.. it was the BIG black plastic piece that goes from tip over to tip over.. i removed it.. cleaned it (just cause i wanted to) and when i reattached it.. i have NOT had noise ever since.. has your bike ever used the tip overs before? my noise after AFTER it fell over on the tip overs..
prp1851
Posted 2015-06-27 9:23 PM (#173030 - in reply to #172848)
Concord, NC
I found where the noise was coming from. The belly pan was rubbing the battery tray. I put some weather stripping around the bottom of the battery tray and no more noise! Thank you all for your suggestions!
