Heated Grips
jdstamp
Posted 2015-01-13 7:22 PM (#169420)
Subject: Heated Grips
Trenton, Ohio
Is it true that the only heated grips that fit the Vision AND controlled by stock toggle switch come from Ma Polaris?
Posted 2015-01-13 8:33 PM (#169422 - in reply to #169420)
Subject: Re: Heated Grips
Yes. Ma Vics heated hand grips use a dual filament heater and thus a double throw toggle switch that either turns one filament on, or both. All others use a single filament and a vary the power to achieve the heat levels. You can use the stock toggle with any of the other grips, but they will always be at full heat. You would need to put the variable controller in somewhere to adjust it. I am using the Avon Heated Grips and mounted the controller next to the radio controls. It has four level settings.
(DSC_0255.jpg)
Attachments DSC_0255.jpg (62KB - 1 downloads)
jdstamp
Posted 2015-01-15 4:49 PM (#169444 - in reply to #169420)
Subject: RE: Heated Grips
Trenton, Ohio
Hmmm, sounds like a resistor and diode are needed. Anybody tried this?
Posted 2015-01-15 5:23 PM (#169445 - in reply to #169420)
go to witchdoctor watch video on install
jdstamp
Posted 2015-01-15 5:29 PM (#169446 - in reply to #169420)
Trenton, Ohio
The witchdoctor video I saw, they drilled a hole in the console for the Avon controller. I would like to use the double throw switch that is already installed.
ljurgens
Posted 2015-01-16 7:36 AM (#169448 - in reply to #169420)
West Salem, WI United States
Hey nozzledog, what is the little knob to the left of your radio controls for?
Posted 2015-01-16 11:39 AM (#169454 - in reply to #169420)
It controls my Clearwater LED driving lights brightness.
Turk
Posted 2015-01-22 7:34 AM (#169514 - in reply to #169420)
I use a potentiometer mounted on the left console skirt instead of the controller supplied by Avon. I run it through the low side of the console switch, and have the high side going direct. The reason for the POT, is that unlike a resistor, it doesn't generate any heat, and it doesn't reset to off every time the bike is restarted like the included 4 way controller. It just maintains it's last setting, based on where I rotate the POT, and which side (usually always on low) I have the console toggled to.
http://www.amazon.com/Variable-Heat-Controller-VHC-2-heated/dp/B006...
Edited by Turk 2015-01-22 7:39 AM
Posted 2015-01-22 6:05 PM (#169522 - in reply to #169420)
use to use Variable Heat Controller back in high schools on my cheapo cars
