HOW DO YOU REMOVE THE FACTORY STICKERS?
bobbybhb
Posted 2008-04-07 6:17 PM (#8052)
Subject: HOW DO YOU REMOVE THE FACTORY STICKERS?
CALGARY ALBERTA
I WANT TO REMOVE THE FACTORY STICKERS ON MY DASH AND DON'T WANT TO SCRATCH OR HARM THE PAINT. WHAT WORKS BEST? THANKS BB
Mudge
Posted 2008-04-07 7:20 PM (#8054 - in reply to #8052)
Subject: RE: HOW DO YOU REMOVE THE FACTORY STICKERS?
20 miles west of Chicago.
Wet and soak with WD40. Warm sticker with a hair dryer. Don't use a heat gun or get it too hot, just moderately warm. Use a fingernail in a sort of scratching/ slicing motion under a corner of the sticker and continue doing this bit by bit for one helluva long time until it's all off. Keep spraying a little WD40 every few minutes to keep it wet and re warm it with the dryer. When all the sticker is off, use a soft cloth and WD40 to get the adhesive residue off. Clean it with isopropyl (rubbing) alcohol and apply wax. It takes a while; best to pull the panel off and do it indoors at a table.
metalguy
Posted 2008-04-07 9:35 PM (#8067 - in reply to #8052)
Subject: Re: HOW DO YOU REMOVE THE FACTORY STICKERS?
Tacoma, WA
Yep. Did that like the second night I had my bike. Looks great without the "dummy" stickers-----Metalguy
Banjo
Posted 2008-04-07 9:38 PM (#8069 - in reply to #8052)
Hair dryer and then WD 40 to remove the glue residue.
Posted 2008-04-07 9:40 PM (#8071 - in reply to #8054)
Mudge - 2008-04-07 7:20 PM Wet and soak with WD40. Warm sticker with a hair dryer. Don't use a heat gun or get it too hot, just moderately warm. Use a fingernail in a sort of scratching/ slicing motion under a corner of the sticker and continue doing this bit by bit for one helluva long time until it's all off. Keep spraying a little WD40 every few minutes to keep it wet and re warm it with the dryer. When all the sticker is off, use a soft cloth and WD40 to get the adhesive residue off. Clean it with isopropyl (rubbing) alcohol and apply wax. It takes a while; best to pull the panel off and do it indoors at a table.
 What Mudge said. However, I used furniture polish to remove the residue.
mike s
Posted 2008-04-07 9:46 PM (#8074 - in reply to #8052)
Valdosta, GA
I removed mine at 80mph while northbound on I-75 on my way home from the dealership. It helped that it hadn't been on there that long (bought 3 days after delivery, 27 Sept) and it was a fairly warm day.
GnAontheRoad
Posted 2008-04-07 10:42 PM (#8082 - in reply to #8052)
Harrisburg, PA
I just removed mine with the hair dryer, and some zippo fuel. Cleaned it up with simple green, polish, then waxed it up. Looks great!
divesharc
Posted 2008-04-07 11:35 PM (#8089 - in reply to #8052)
VA
Goo be gone works well too. It's citrus based, so there's no really bad chemicals, that I know of, in it. We used it on our bathtubs after we moved into our house to remove the liquid nails that the drywallers left behind. I will say though, I expected that sticker to just peel off. Not a chance. I don't know why they thought they needed to use superglue to adhere the sticker.
pault754
Posted 2008-04-08 1:08 AM (#8094 - in reply to #8052)
El Paso, TX
I left mine in the sun one afternoon for a little while. I then used my wifes hair dryer to heat it up some more and was able to peel it right off. It did leave some adhesive residue, but I was able to clean it off with some wd-40. Looks like it was never there now.
