Passenger Floorboards and Risers - Loose
Posted 2009-12-28 6:37 PM (#50341)
Subject: Passenger Floorboards and Risers - Loose
After almost 14,000 miles I finally addressed an issue that has been bugging me from day 1.
The rear floor boards and the risers for the rear floorboards felt loose.
Many posts here have discussed that if split ring on the rear floor boards breaks, the pin that hold on the rear floor board will fall out and the rear floor board will fall off.
So when I installed my chrome rear tipover covers, I decided to replace the pins with stainless bolts and nylon lock nuts. I also replaced the M6 x 50mm bolts that let the risers flop around.
At Home Depot I bought two 5/16" by 2 1/2" stainless steel bolts for the floor boards, two 5/16" by 2" stainless steel bolts for the risers, four 5/16" nylon lock nuts, and eight 5/16" lock washers.
I had to tap the 5/16" by 2" stainless steel bolts for the risers with a small hammer to get them in place. The risers no longer flopped around after that.
Then I installed the 5/16" by 2 1/2" stainless steel bolts for the floor boards.
They still flop around some but not near as bad as they did before. At least now I do not have to worry that the split ring will break and the floorboard fall off.
Ride Safe!
vicktor
Posted 2009-12-29 12:10 PM (#50365 - in reply to #50341)
Subject: RE: Passenger Floorboards and Risers - Loose
Reverse the pin and insert the clip and it will never break again. To tighten the floorboards all you have to do is stretch the spring which will apply more pressure to the floorboards.
Posted 2009-12-29 1:33 PM (#50368 - in reply to #50365)
vicktor - 2009-12-29 12:10 PM
This maybe true....but I like the bolts.
The riser blocks flopping is due to the small diameter of the M6 bolt. With the 5/16" x 2" stainless bolt in the block, the risers are solid to the rear tipovers.
Ride Safe
outdoordave48
Posted 2009-12-29 2:37 PM (#50372 - in reply to #50341)
Subject: Re: Passenger Floorboards and Risers - Loose
Eau Claire WIS. 09 vision
teach i did the same thing works alot better than pins.. dave
Posted 2010-01-03 10:17 PM (#50649 - in reply to #50341)
vicktor,
Thanks for the advice on stretching the springs. That works really nice.
Ride Safe!
DrDecay
Posted 2011-06-11 10:55 PM (#88618 - in reply to #50341)
Apopka, FL
I'm confused, the passenger floorboards I understand. I will make that change tomorrow because I am missing one clip. Where I'm confused is, what are the "risers" you are talking about? My passenger floorboards are bolted through a bracket which is a solid part of the rear tip-over. Second question, what springs are you talking about? the ones for the driver (front) floorboards?
river v
Posted 2011-06-12 9:58 AM (#88634 - in reply to #50341)
Fort Myers, FL United States
Risers--"passenger floorboard relocation kit"--are blocks that raise the floorboards about an inch.
Victory Motorcycles Victory Vision Passenger Floorboard Relocation Kit - pt# 2876260
DrDecay
Posted 2011-06-12 11:31 AM (#88638 - in reply to #88634)
Apopka, FL
river v - 2011-06-12 10:58 AM
Ok, thanks for the clarification. I don't have those.
glighto11
Posted 2011-06-12 11:35 AM (#88640 - in reply to #50341)
Central New York
You may want to check out the risers, many people find them more comfortable.
