Ness Saddlebag Insert Pictures needed
V-rodder
Posted 2015-04-12 3:46 PM (#171796)
Subject: Ness Saddlebag Insert Pictures needed
Anyone have the ness saddlebag inserts for lowered visions?  I am thinking about them and wanted to see what they look like installed.
Thanks,
Jim
Posted 2015-04-12 6:03 PM (#171799 - in reply to #171796)
Subject: Re: Ness Saddlebag Insert Pictures needed
There the same as stock but narrower. Bet your thinking if you change them you can put on a bigger tire
(BAG-INNERS42-163.jpg)
Attachments BAG-INNERS42-163.jpg (18KB - 3 downloads)
V-rodder
Posted 2015-04-12 7:12 PM (#171804 - in reply to #171796)
I am really looking for pictures of them installed. Trying to get an idea of how they are installed. I want to lower my vision 3" in the rear and 1.5" in the front. I have the 1" rear link now.
Thanks
Jim
V-rodder
Posted 2015-04-16 9:33 PM (#171914 - in reply to #171804)
Hey John, I just saw a picture of your gray Vision on the VF site. What drop do you have front and rear on your bike?
Thanks,
Jim
Posted 2015-04-17 4:42 PM (#171925 - in reply to #171796)
I cut a inch out of the factory rod. Guess thats like dropping 2 inches. I did spacers up front 1 inch with new bolts 1/2-13 don't remember how low long.
Not sure you can do 3 inches in back cause of the angle you would put on the belt. You would have to modify the front sprocket cover for sure.
Even with all the dropping you plan on doing there might not be enough adjustment to get the headlight down
V-rodder
Posted 2015-04-17 8:06 PM (#171932 - in reply to #171796)
Well the hmd520 link does 2" and 3" with no mods other than the ness bad inserts and kick stand. Supposedly. May just do 1" front and 2" rear.
conn-e-rot
Posted 2015-05-01 7:13 AM (#172184 - in reply to #171796)
Conneaut, OH
mine has been lowered 1 1/2" rear 1" front for 2 or 3 years with stock bags and I have never had an issue just have to make sure you have enough air in the shock and dont take it offroading.
V-rodder
Posted 2015-08-09 9:18 PM (#174161 - in reply to #171796)
Subject: RE: Ness Saddlebag Insert Pictures needed
Installing the Ness inserts.  Do I need to trim the bottom away as well?  I didn't think there was a depth issue.  I would prefer to leave the lip on the bottom for strength.  Here is a picture of the Right Bag.
Edited by V-rodder 2015-08-09 9:19 PM
Posted 2015-08-10 6:23 PM (#174178 - in reply to #171796)
guessing you cut to fit. Maybe call Ness
