Any negatives to the LLoyds Touring Cams?
V-rodder
Posted 2015-04-07 8:39 AM (#171700)
Subject: Any negatives to the LLoyds Touring Cams?
I have a 2011 Vision. It currently has the Ness Honkers, Both Ness Air Cleaners, PCV w/ Custom Map, and the LLoyds Timing Wheel. I am looking at getting the Idle Air Valve, Touring Cams, and 1/4 Throttle Ring at the Myrtle Beach Rally.
Since my Vision is so smooth and comfortable now, I want to make sure it stays that way after any mods. My concerns are heat (I already have the lower air deflectors), increased vibration, and decel pop/backfire. I've read all the great reviews, but I just want to make sure I know the good and any bad.
Thanks
Jim
kin52
Posted 2015-04-07 3:03 PM (#171702 - in reply to #171700)
Subject: RE: Any negatives to the LLoyds Touring Cams?
Louisville, KY
I did the touring cams on my vision. the valve train noise seems about the same the only difference I noticed is more power.
It takes a good bit of cutting on the cam carriers to get the cams into the cam carriers. the only issue I could see getting the work done at a rally is will they be able to do the amount of cutting needed in a short amount of time. In addition to clearing the carriers the rocker arms need to be cleared as well or there will be interference at the higher lift.
You are also going to need to redo the PC-V map after the cam change.
V-rodder
Posted 2015-04-07 5:40 PM (#171707 - in reply to #171700)
Subject: Re: Any negatives to the LLoyds Touring Cams?
I spoke to them and they bring carriers, etc with them to save on time.
Jim
Posted 2015-04-08 5:53 PM (#171722 - in reply to #171700)
with the PCV I don't think there is a need for the IAV
adirondacks
Posted 2015-04-08 7:34 PM (#171724 - in reply to #171700)
Troy, NY
The only negative I have is not doing them sooner. I would also not upgrade my exhaust to S1L1 and just spent that money to upgrade the CAMS. I have 26K on the cams......no complaints.
JustBob
Posted 2015-04-08 10:20 PM (#171732 - in reply to #171700)
My only negative is My wrist getsa workout from twisting the wick so much.
V92SC
Posted 2015-04-09 6:55 AM (#171733 - in reply to #171700)
New Orleans, La,
Not coming from the factory with them.
V-rodder
Posted 2015-04-09 7:10 AM (#171734 - in reply to #171700)
Well coming from the HD world, I was mainly concerned with adding heat and vibration. Seems those are two more problems I am leaving behind with the Freedom 106.
Jim
lstayner
Posted 2015-04-09 12:54 PM (#171739 - in reply to #171734)
V-rodder - 2015-04-09 7:10 AM
Jim
There is heat on a Vision but not to bad. The best money spent on cooling are the lower deflectors. They make the bike more enjoyable to ride in hot or cold conditions,
