Fast idle at warmup
Dean
Posted 2015-11-18 9:01 AM (#176649)
Subject: Fast idle at warmup
Charleston, WV
O8 vision 43k, started fast idle around 42500only durnig warmup (above 2k), after warmup it idles at normal rpm Any ideas?
Posted 2015-11-18 9:32 AM (#176650 - in reply to #176649)
Subject: Re: Fast idle at warmup
check your vacuum lines off of the IAC would be my first look.
Posted 2015-11-18 5:54 PM (#176655 - in reply to #176649)
your boots might be rotted away
(bad rubber.jpg)
Attachments bad rubber.jpg (96KB - 0 downloads)
Travler
Posted 2015-12-01 6:15 PM (#176778 - in reply to #176649)
Subject: RE: Fast idle at warmup
SE Florida
I had the inlet boots separate from the aluminum plate on my 08 Vision and it caused a fast idle during warm up. An easy way to check for a vacuum leak is to spray carb cleaner around the boots with the engine running if you have a leak the rpm will change when you spray the cleaner.
Posted 2015-12-02 1:18 PM (#176808 - in reply to #176778)
My boots on my 2008 also separated. They looked fine until you reached in with a fingernail and tugged at the rubber. It would pull away from the aluminum. It isn't supposed to.
Throttle Body Adapter. Part number 1203866.
Posted 2015-12-04 5:18 PM (#176825 - in reply to #176649)
Guess Dean never got it fixed
Dain
Posted 2016-01-27 2:46 AM (#177441 - in reply to #176649)
Yes Throttle body adapter plate had the same thing happen to mine its like 65 bucks.
Dain
rodhotter
Posted 2016-01-31 2:02 PM (#177503 - in reply to #176649)
i am always interested in problems + fixes + appreciate when a repair is acknowledged, for future reference.
