Stereo Muted, no sound
cycledaddy57
Posted 2011-04-16 1:35 PM (#84121)
Subject: Stereo Muted, no sound
HI. I have a problem with my stereo on my VIsion. My stereo acts like the mute is on all the time, no sound. Does anyone know how I could isolate the problem or have any ideas on what to check? If you have any idea could you call me at 616 698 7243.
Thanks Cycledaddy57, Sim Maier
Email- Smaier57@aol.com
Cap'n Nemo
Posted 2011-04-16 2:12 PM (#84130 - in reply to #84121)
Subject: Re: Stereo Muted, no sound
New Bohemia, Va
try ensuring all of your plugs under the console is tight. slap some dielectric grease in there while you are at it. Hope it get's you fixed.
BillyJoe
Posted 2011-04-16 2:21 PM (#84131 - in reply to #84121)
, AR United States
Not going to call, but I will send this in an email. My 09 vision radio went silent 2 months after I got the bike, but still showed the display. The dealer tried the software upgrade, but that didn't help. After phone calls to Victory they replaced the radio. The new one worked for a while and then started going off completly- sound and display- at random. They replaced the stereo again and it has worked ever since. I hope yours is still under warranty.
Billy
sgiacci
Posted 2011-05-03 11:07 AM (#85413 - in reply to #84121)
Go thru the radio menu and make sure the ext. speakers are turned on.
nailer
Posted 2011-05-03 11:46 AM (#85414 - in reply to #85413)
Albuquerque, NM
Bad mute button on the left handlebar control pod??
Posted 2011-05-03 11:57 AM (#85416 - in reply to #85413)
sgiacci - 2011-05-03 11:07 AM
Check on what sgiacci says above.
If it is not that you chances are that the radio is bad. Bummer.
#57
Posted 2011-05-03 1:08 PM (#85418 - in reply to #84121)
Seems like a lot of stereo problems, including mine have an easy fix. Unplug the negative battery cable for a few minutes.
Worth a try. Mine has worked fine since.
mkultra
Posted 2011-05-03 2:40 PM (#85427 - in reply to #84121)
Tucson, AZ
Negative battery cable fixed mine also...its the first thing I try now.....
mike
