HELP!!!! Oil Pressure light is on
Easttexasrider
Posted 2009-07-22 8:38 PM (#39373)
Subject: HELP!!!! Oil Pressure light is on
Lindale, TX
Oil Pressure Light stays on after engine starts. I checked oil and its right at full. I have 3084 miles on the Vision and changed over to AMSOIL at 500 miles. Shut off the bike and headed here.
Teach
Posted 2009-07-22 8:43 PM (#39375 - in reply to #39373)
Subject: Re: HELP!!!! Oil Pressure light is on
Let me guess you either just washed your bike or rode in the rain? Sounds like you have a bad oil sending unit. Victory stamped some wrong so they allow moisture in and a false oil light is the result. It is located on the left rear underside of the motor just in front of where the pipes turn in on the left to go under. Couple small wires and a rubber boot covering it. So if you haven't gotten the bike wet check the wires there.
Easttexasrider
Posted 2009-07-22 8:46 PM (#39377 - in reply to #39373)
Lindale, TX
I just washed and waxed the bike
Easttexasrider
Posted 2009-07-22 8:47 PM (#39378 - in reply to #39373)
Lindale, TX
I'll let it dry
Teach
Posted 2009-07-22 8:48 PM (#39381 - in reply to #39373)
Could take a while before the light fully goes out even a couple days. Let your dealer know it has a bad one so they can replace it.
Teach
Posted 2009-07-22 8:49 PM (#39382 - in reply to #39373)
Easttexasrider
Posted 2009-07-22 8:49 PM (#39383 - in reply to #39373)
Lindale, TX
Panic had set in Teach. Thank you.
