Lose the reflectors on the front forks....
Lotzafun
Posted 2008-10-01 3:58 PM (#19496)
Subject: Lose the reflectors on the front forks....
Rockford, IL
Was pondering removing the reflectors off the front tubes. I assume they are attached with double-sided tape...correct? So a little heat and somewhat well placed hit with a 15lb sledgehammer will do the trick
There isn't any type of "pin" or anything else holding them on...is there?
Wizard523
Posted 2008-10-01 4:53 PM (#19502 - in reply to #19496)
Subject: Re: Lose the reflectors on the front forks....
Woodland Hills, CA
I took mine off as well. No pins, just the tape. It took longer getting the residue off the fork legs than it did removing the reflectors.
VisionTex
Posted 2008-10-01 5:45 PM (#19508 - in reply to #19502)
LaPorte,Tx.
I had one fall off already, can't be too tight. I bought a couple reflectors from auto parts store, stuck on fine. Why do you want to take them off?
devilboy
Posted 2008-10-01 6:52 PM (#19514 - in reply to #19496)
Subject: RE: Lose the reflectors on the front forks....
Central Florida
Nope Nothing holding them on but adhesive.
when I POWDERCOATED front fork legs I left them off.
Might put LEDs on or might just leave it alone.
Lotzafun
Posted 2008-10-02 9:38 AM (#19575 - in reply to #19508)
Rockford, IL
VisionTex - 2008-10-01 4:45 PM
I want to take them off because I feel they "interupt" the looks of the tubes, or to be a bit more blatant...they look yicky-yucky.
And I think there is a fairly minimal (if any) safety benefit to having them on there.
Heading out to grab the sledgehammer !! Wonder if I can use a torch for the heat source
Rebel
Posted 2008-10-02 12:32 PM (#19596 - in reply to #19496)
Linwood, MI
Blow dryer and a plastic putty knife might be safer...
Yuma48
Posted 2008-10-03 7:20 PM (#19747 - in reply to #19496)
San Diego, California
To remove stickers or reflector you can use dental floss in a sawing motion, no scratches afterward.
