2009 Vision Mirror Vibration FIX
whinecooler
Posted 2009-10-06 4:31 PM (#45380)
Subject: 2009 Vision Mirror Vibration FIX
Litchfield Park, AZ
Not that it ruined my day riding, but the right mirror on my Vision would vibrate really bad 2000-3000 RPM, right at cruising speeds, smooth freeways and regular 2-laners.
Now, I've had a chopper and both mirrors and handlebars vibrated to beat hell, with no possible fixes because of so much frame and engine vibration.
But I had an idea I used to employ to resolve vibration issues when I was an automobile manufacturer's technical rep, and I tried it on the mirror vibration problem on my Vision and it worked!
Vibration is harmonic, influenced by mass/density and frequency. Your goal, change one of the variables. The only option is to change the density. I stopped by my local custom wheel dealer and mooched a strip of adhesive wheel balancing weight 4oz. I cut in into 3 pieces. Removed the mirror, stuck the weights on the back of the mirror and reinstalled it. I took it for a ride. No vibration at any speed. No interference in the mirror adjustment cause there's plenty of room behind the mirror.
The left mirror has never vibrated, but if it did, I am confident this would work there also. Give it a try if yours is vibrating. No harm, eh?
SP
(rsz_img_0023.jpg)
Attachments rsz_img_0023.jpg (59KB - 13 downloads)
Posted 2009-10-06 5:42 PM (#45385 - in reply to #45380)
Subject: Re: 2009 Vision Mirror Vibration FIX
NICE WORK!
Posted 2009-10-06 5:49 PM (#45386 - in reply to #45380)
I would add the to the Tech Reference section. I will give it a try.
Thanks
bigwill5150
Posted 2009-10-06 6:19 PM (#45387 - in reply to #45380)
Reno County, KS
Yes! Mine does the exact same thing! I mentioned it last year and no one else seemed to be having a prob with theirs. Thanks for the fix!
whinecooler
Posted 2009-10-06 7:06 PM (#45390 - in reply to #45380)
Litchfield Park, AZ
One thing also, DO NOT LUBRICATE THE MIRROR TRACKS on the back side of the mirror! They need to remain dry and have friction.
If you still have some vibration, you can try 4oz of weight. There is room for it. I put on 3oz and stopped there. When you reinstall the mirror, be sure to make the 10mm bolt on the backside good and tight and the top allen as well. SP
wroman
Posted 2009-10-11 7:00 PM (#45679 - in reply to #45380)
Gettysburg, 2008 Tour Premium
My left mirror does about the same. I was thinking of doing what you dif and glad to know it works.
