New Rear Shock Assembly Question
southjerseyrider
Posted 2017-02-08 4:16 PM (#191460)
Subject: New Rear Shock Assembly Question
Vineland, NJ United States
I had a new rear shock and shock mount arm (rocker thingie) installed by dealer.  I noticed the part number of the new shock is different than my original 2008 OEM shock.  Did the air pressure chart change also? The new setup feels much stiffer than old even when I lower the pressure a little. Any thoughts?
Posted 2017-02-08 5:55 PM (#191461 - in reply to #191460)
Subject: Re: New Rear Shock Assembly Question
yes the shocked changed in 2011 but I didn't find where the air pressure changed
Davet
Posted 2017-02-11 7:19 AM (#191469 - in reply to #191460)
Sacramento, CA United States
DUDE! It's a new shock. I'd 'ope it would be stiffer (no?).
Posted 2017-02-11 12:12 PM (#191470 - in reply to #191460)
Theres a reason why you replaced it
southjerseyrider
Posted 2017-02-12 8:53 AM (#191471 - in reply to #191469)
OK, I deserve that but what I mean is even when I go from 50lbs to 25lbs, I don't feel much difference, it still feels the same level of stiffness?  Maybe it needs a break-in period.....I'll put a few more mile on it and see if things change.
Posted 2017-02-12 6:15 PM (#191472 - in reply to #191460)
well if the old one was worn out how could you compare that to the new
