Cam answer carrier part number change
Posted 2016-08-05 9:23 PM (#188010)
Subject: Cam answer carrier part number change
This is nothing big or mind blowing, I was just wondering if anyone knew why in 2015 the Cam Carrier part numbers changed and then changed Again for 2016 ( vision ) then I noticed the actual cam part number changed for 2016 .
Just wondering if there was any reason or improvement?
Posted 2016-08-06 5:50 PM (#188027 - in reply to #188010)
Subject: Re: Cam answer carrier part number change
2016 all models or motors the cam carriers changed. Maybe different vendor. Cams stayed the same.
Might be something to do with the s&s new cams
Posted 2016-09-22 3:17 PM (#189020 - in reply to #188010)
Huh ??
Posted 2016-09-24 5:04 PM (#189038 - in reply to #188010)
what don't you understand. Most places when they changer vendors change part number in case of problem.
Now that s&s is making a performance kit for Vic's they might of needed more clearance for there cams
Posted 2016-09-25 8:43 AM (#189045 - in reply to #188010)
so thats what happened then... they changed Vendors ? has nothing to do with their revised horse power and Torque numbers?
Posted 2016-09-25 5:34 PM (#189054 - in reply to #188010)
didn't they lower the horsepower
