Brakes
willieh
Posted 2016-06-22 7:39 PM (#184932)
Subject: Brakes
huntington In.
Had a new E4 mounted on the rear today. Found out that I need new brakes and rotors. OEM parts come to almost $1000. For that kind of money I'm thinking I should be able to up grade the brakes and make it stop better. I need your guidance and suggestions please.
Posted 2016-06-22 8:14 PM (#184933 - in reply to #184932)
Subject: Re: Brakes
eBay for low mileage rotor. That's what I did anyways.
Posted 2016-06-23 6:07 AM (#184934 - in reply to #184932)
Subject: Re: Brakes
that seems really really high.. when i bought a NEW rotor for my rear wheel it was $199.. so times that by 3 if you needed all 3... but like Varyder said... ebay... all day long....
i just had to replace a kickstand.. dealer wanted i think close to $300 i got one on ebay for $39 and its perfect...
willieh
Posted 2016-06-23 7:39 AM (#184936 - in reply to #184932)
Subject: Re: Brakes
huntington In.
dealer wants $260 a rotor and $52 a set for brakes.
cw1115
Posted 2016-06-23 2:07 PM (#184938 - in reply to #184932)
Subject: Re: Brakes
Ruskin, Fl
I upgraded to Lyndall in the rear, $65 a set. Still using the stock rotor at 49,000 miles. I plan on putting them up front when the EBC pads need replacing. I notice an improvement with just the rear set. I looked at carbon fiber rotors. YIKES! Big money.
Posted 2016-06-23 6:13 PM (#184945 - in reply to #184932)
Subject: Re: Brakes
look in owners book it will give you spec's on what rotor thickness should be.
Witchdoctor has way better brake pads that will stop you better the oem for less then 50 bucks.
you know the rear brake is to slow you down and the front are for stoping
