Tire plug
Jimbo62
Posted 2014-09-19 12:42 AM (#165953)
Subject: Tire plug
Has anyone had to plug a punctured front or rear tire? And if so was this a temp fix or did you run the tire until worn out? I just pulled a 2 inch nail from my rear tire. I feel I have a few thousand miles left on it, but not sure if I should just replace.
Posted 2014-09-19 6:43 AM (#165956 - in reply to #165953)
Subject: Re: Tire plug
Yes. See my post here with pictures:
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=17676&po...
gkiselyk
Posted 2014-09-19 7:47 AM (#165957 - in reply to #165953)
Subject: RE: Tire plug
removed a screw this spring. Clean hole so I reamed it out and installed a plug myself. I put just under 5K miles on that plug before I changed the tire out. No problem.
ljurgens
Posted 2014-09-19 9:02 AM (#165958 - in reply to #165953)
West Salem, WI United States
I plugged a rear tire on my Pin last year. I ended up changing it because I was going on a long trip and the bank where I got the screw actually replaced the tire for me. They had construction going on and I matched the screw from my tire to screws in the parking lot there!
I have heard of guys using the patch plug which is a patch with a plug end that you put on from the inside of the tire.
Jimbo62
Posted 2014-09-19 7:46 PM (#165962 - in reply to #165953)
Thanks for all the input. I will plug the hole. But my other half has little faith in the process. So I will take to a friend who runs his own shop and have him pull the wheel and patch it from the inside.
Posted 2014-09-21 6:27 AM (#165988 - in reply to #165953)
i plugged one of my tires years ago and rode with it plugged for over a year.. BUT... i was using a CT... (darkside) hell right now... i have had a nail in my back tire for almost 2 years.. never removed it ! its a small nail, doesnt leak air... also a CT (good year assurance fuel max)
