Accent,light electrical problem/ uck
sonicbluerider
Posted 2016-06-04 1:41 PM (#184523)
Subject: Accent,light electrical problem/ uck
, IA
Wife's New bike came with accents light's on it. They worked. Had New battery put in ,never ran accent light's until a few days ago.NO LIGHTS. Checked fuse/lost fuse replaced 3amp 250 with a 2 amp 250 - light a no go. Find a wire in front not connect. Set it on positive post. Lights do not work. Ok take the one that's on negative post put it on positive post and place first one on neg.post .great light's. Or so I though. Lights, light but won't turn off. HELPPPPPPP
2014 cct csc trike ,2010 crossbow.
Posted 2016-06-04 5:42 PM (#184524 - in reply to #184523)
Subject: Re: Accent,light electrical problem/ uck
you shorted out something start tracing
Posted 2016-06-05 10:52 PM (#184533 - in reply to #184523)
Is the lights on a switch. If so is the switch on and that's why it wouldn't go off
sonicbluerider
Posted 2016-06-06 5:11 PM (#184550 - in reply to #184523)
, IA
I wish entertain said blown unit. Oh well
icemann
Posted 2016-06-07 9:12 PM (#184567 - in reply to #184523)
, OH
are they after market lights or the side badge lights, or the dash lights? if they are aftermarket lights there is probably a remote to them. Which means there is a module near the power wires to the lights. If so then the relay is stuck or just needs by passed with a switch. If they are LED lights on a strip then on one end or the other the copper is touching the bike somewhere causing a ground to create power for you.
sonicbluerider
Posted 2016-06-14 3:15 PM (#184685 - in reply to #184523)
, IA
Bad switch replaced and lights work Yaaaaaaa!!!!
