tail/brake lightbulbs
azllerbob
Posted 2016-01-14 11:51 PM (#177228)
Subject: tail/brake lightbulbs
Parkersburg WV
Does anyone know of a better bulb to use than the stock ones ?
thanks, Bob
Posted 2016-01-15 4:29 AM (#177229 - in reply to #177228)
Subject: RE: tail/brake lightbulbs
Not really.. cause if you go with a LED bulb now you risk the cruise control not working unless you do a few options to modify the resistance value .. there are other options like what i have.. but they are much more complex than just replacing a bulb.. but these option completely blows away the cheesy 6 bulb stock configuration..
http://www.radiantz.com/product-p/9070-00.htm
j.wales
Posted 2016-01-15 3:06 PM (#177238 - in reply to #177228)
Subject: Re: tail/brake lightbulbs
Asheville, NC
I emailed Radiantz. They were very nice. They emailed the installation instructions so I could take a look and them decide if I want to purchase. They are working on a different load equalizer / flasher set up. I may wait to see what they modify until the tax return comes back. Thanks for the link.
Edited by j.wales 2016-01-15 3:07 PM
Posted 2016-01-15 6:10 PM (#177239 - in reply to #177228)
if you need bulb go to auto store ask for long life and bright. way cheaper.
Have you done this
https://www.youtube.com/watch?v=5-QPAMpVmhw
Posted 2016-01-16 10:15 AM (#177249 - in reply to #177238)
j.wales - 2016-01-15 3:06 PM
the load EQ / flasher mounts under the radio.. so the lights would be the same.. im glad you shared about the load eq cause that makes sense on why i didnt see one on their website for a while.. i have had this setup for a while. its the MOST complemented mod on my vision.. when ever someone see these lights in action and then on a bike like a vision it elevates the whole WOW factor 10 fold... those little whimpy 6 bulbs arent even in the same league as the Led Radiantz setup...!! want a truly Brighter, and more CUSTOM look.... your not going to get that with 6 little cheap bulbs..
