Lower Deflector Adhehesive
glighto11
Posted 2010-03-01 3:30 PM (#54146)
Subject: Lower Deflector Adhehesive
Central New York
Got a set of Lower Deflectors to install but the instructions don't give a temperature tolerance for the adhesive. Anybody seen anything on this? Anybody tried this in colder weather?
Lotzafun
Posted 2010-03-01 3:52 PM (#54147 - in reply to #54146)
Subject: Re: Lower Deflector Adhehesive
Rockford, IL
Take a look here http://www.vision-riders.com/bb/forums/thread-view.asp?tid=1689&pos...
And here http://www.vision-riders.com/bb/forums/thread-view.asp?tid=2020&pos...
About the only rule you MUST/SHOULD/BETTER follow is to WAIT the 24 hours !!!
markh
Posted 2010-03-01 5:23 PM (#54155 - in reply to #54146)
Newbury Park CA
Don't glue them, take the time and bolt them on. They will only come off if you want them too.
VaParadox
Posted 2010-03-02 10:18 PM (#54236 - in reply to #54146)
Richmond, Virginia
Ive put on two sets. Neither have come off. Make sure you use the alcohol prep and remove all the wax off the panel. Then take a blow dryer and warm up the plastic where the adhesive will attach. Once you place the deflectors in the proper position LEAVE EM ALONE, dont open close open close open close for 24 hours. After that THEY WONT COME OFF.
okthenbye
Posted 2010-03-02 11:02 PM (#54240 - in reply to #54146)
Stockton, Ca.
Cleaning with the alcohol prep and allowing 24 hour cure time is the key. I have mine on for 2 years and they are as sturdy as they were day 2, after the 24 hour wait.
