speakers
Byarddog
Posted 2015-10-05 7:54 PM (#175300)
Subject: speakers
I had JBL speakers in the front and stock in the rear. I could hear the front but not really the rear. I upgraded my front speakers to alpines because i blew a jbl. and witchdoctor sells Alpines. Now i can hear the stock rears better than the front?
nailer
Posted 2015-10-05 8:48 PM (#175302 - in reply to #175300)
Subject: RE: speakers
Albuquerque, NM
Adjust the fader control?
Or
Stock speakers are 2 ohm I believe. The alpines are probably 4 ohm and require more power to drive them. Your best bet is to replace the stock rears with 4 ohm speakers and add an amp. Or, replace the fronts with another set of 2 ohm speakers and no amp will be needed.
nailer
Posted 2015-10-05 8:48 PM (#175303 - in reply to #175300)
Albuquerque, NM
Or
Byarddog
Posted 2015-10-05 10:59 PM (#175308 - in reply to #175300)
Thank you for your reply. I dont think i will change them it was to hard to get the little rubber gromments to stay in. Might have to install an amp.
Posted 2015-10-06 8:35 AM (#175309 - in reply to #175300)
Subject: Re: speakers
stock speakers are 3.8 ohms. (4) make sure you matched the impedance.. also
look at this... sensitivity rating http://www.audioholics.com/loudspeaker-design/loudspeaker-sensitivi...
Edited by Arkainzeye 2015-10-06 8:36 AM
