rear brake
outdoordave48
Posted 2012-03-15 3:45 PM (#110181)
Subject: rear brake
Eau Claire WIS. 09 vision
hello all, unwarpped the bike yesterday. started right up after a 10 min. warm up went aroud the block a couple of times to warm the oil up and discovered i have no rear brakes. petal goes all the way down, topped off the main res. then bled the brakes still nothing. got fulid out when bled but still no petal. any one have problems with the master on a 09 tour pre. 9,000 miles. Thanks Dave
Posted 2012-03-15 3:59 PM (#110184 - in reply to #110181)
Subject: Re: rear brake
If you do a search for this u will find the front and rear brakes are linked and you more than likely still have air in the lines. There has been alot of talk on this subject.
outdoordave48
Posted 2012-03-15 4:06 PM (#110186 - in reply to #110181)
if i push harder on the petal the front kicks in but there is no pressure on the petal, no leaks seen was fine when i put it away.
outdoordave48
Posted 2012-03-15 5:53 PM (#110195 - in reply to #110181)
ok did the search on brakes and blead the rear and front now i have braks again still seem a little soft so i will do nit again tomrrow. thanks dave
brucehaslam
Posted 2012-03-19 8:30 AM (#110419 - in reply to #110195)
Mesa, AZ United States
Try bleeding the front right brake caliper using the middle nipple. You have to refill the reservoir that is located in front of the engine, inside of the forward cowling, just behind the front wheel. Had the same problem with my 2008 Vision and a 2010 8-Ball. Seems to be a common problem.
