Amps, amps and more amps
alohaboy
Posted 2012-03-06 11:38 AM (#109348 - in reply to #107439)
Subject: Re: Amps, amps and more amps
Danville, CA
Concur...Hawg wired is the solution if you want to do it right and have the spare cash for it.. 3rd set for me...
Kelvininin
Posted 2012-03-06 12:07 PM (#109349 - in reply to #107439)
Subject: RE: Amps, amps and more amps
I don't necessarily agree. I think that Hawg Wired but together a good small package, it works well for those who don't want to tinker, but much like HD, I think you are paying a lot for the name.
The Hawg wired amps are a class T, which is technically a class D, the RF amp is a class AB, and the Arc is a class H.
From a class standpoint the Hawg Wired will pack the most punch with the highest distortion, of the three available amps for the size, class D amps are often used for Sub woofers due to their higher level of distortion compared to the other amps, but typically class D amps are smaller.
The RF and the Arc amp will have a similar level of distortion with Arc being slightly better but the H class is much more efficient compared to the class AB of the RF. This means for the Arc amp, for the same level of power output, about the same or less distortion, plus you get a lot less heat. The trade off is size. Since I think Heat killed my RF amp I upgraded to the Arc amp. From the seat of the pants feel the Arc could blast circles around the RF Amp. Plus the build quality of the Arc is leaps and bounds over the RF.
At the end of the day I still have a few hundred less in my setup than the cost of the Hawg Wired amps alone.
The Vision is already a bad plat form for audio equipment, I didn't want to make it worse by adding a higher distortion amp that cost more.
But to each their own.
Posted 2012-03-07 5:14 PM (#109444 - in reply to #107439)
Kelvininin,
Do you have a link to the Arc amp? I am always open to a better idea.
Ride Safe
nailer
Posted 2012-03-07 5:24 PM (#109446 - in reply to #109346)
Albuquerque, NM
Been checking it out also...kinda pricey. I guess you get what you pay for. $400 on their site
http://store.arcaudio.com/products/productdetail/part_number=KS%201...
Kelvininin
Posted 2012-03-07 5:25 PM (#109447 - in reply to #109444)
Radio,
Here is the link to the Arc KS125.4 from the manufacturer..
http://www.arcaudio.com/product-pages/amplifiers/ks-series/ksm1254....
Here it is on ebay.
http://www.ebay.com/itm/ARC-AUDIO-KS-125-4-MINI-NIB-/160733132967?p...
Once I find a home for it I will have to find pictures of where I put it.
SS_Twin
Posted 2012-11-12 12:18 PM (#126594 - in reply to #109447)
Fernandina Beach, Florida
Kelvinin, any update to your investigation.? What amp/speakers did you wind up going wityh? Any pics?
I'm about to be a new Vision owner (11/17/12 pick up), and will be looking at audio upgrades pretty soon after. Hopefully it was a great and successful project.
Thanks, and I look forward to a great ride onmy Vision and great times with all of you.
Will be doing a formal intro after I get the bike home (sorta superstitious about that).
Steve
cw1115
Posted 2012-11-12 5:58 PM (#126623 - in reply to #107439)
Ruskin, Fl
Does the RF PBR300x4 fit on top of the left fuel tank same as the Alpine amp?
Kelvininin
Posted 2012-11-13 1:03 PM (#126676 - in reply to #107439)
I have the arc amp. The RF PBR300X4 burned up in less than three months. The arc amp is a far superior amp in construction, performance, heat management and quality. Had I to do over again, I would have gone straight to the arc amp.
Posted 2012-11-13 3:45 PM (#126683 - in reply to #107439)
My RF PBR300X4 died as well. I feel bad for recommending it to everyone.
Live and learn.
Ride Safe
baadawg
Posted 2012-11-13 5:09 PM (#126691 - in reply to #107439)
Chattanooga, TN
My RF PBR300X4 is still running fine, did the install this spring, and I like it loud! I took it to a stereo shop and they adjusted the outputs to the point of speaker distortion with the head unit volume at 27 or 28 and measured it with an oscilloscope(?). Of course, I bought the extended warranty which is prolly the real reason it hasn't failed. Give it one year and a day....
cw1115
Posted 2012-11-13 5:35 PM (#126695 - in reply to #107439)
Ruskin, Fl
Baadawg, I have finally made up my mind on Polk MM521 speakers. I really want to do the RF amp. The MM521 are 15-90W peak of 200W, marine certified.
Where is your amp mounted? If it won't fit on top of the left fuel tank I may do the Alpine. My saddlebags are very often packed full. The Arc amp is out of my budget at this time.
baadawg
Posted 2012-11-13 6:40 PM (#126705 - in reply to #107439)
Chattanooga, TN
I put mine in the left side saddlebag, mounted against the front so it might benefit from a cooler surface and cooler running pipe. I've thought about putting wire mesh of some sort around it with a computer fan blowing on it, that way I can pack more in that side. It does get hot, but not as hot as it did before I took it to a car stereo shop so they could analyze it.
My speakers are only rated for 135 watts/pair. I'll have to check those other ones out! Since yours can handle more power, your amp will likely run hotter, but it isn't waterproof. Good luck on your install!
(2012-11-13 19.27.37 Saddlebag amp install.jpg)
Attachments 2012-11-13 19.27.37 Saddlebag amp install.jpg (14KB - 4 downloads)
cw1115
Posted 2012-11-13 7:22 PM (#126708 - in reply to #107439)
Ruskin, Fl
Thanks. The MM521 list for $229 a pair. Several new on eBay in the 120-140 range.
victoryvisiontour
Posted 2012-11-13 8:06 PM (#126711 - in reply to #126623)
cw1115 - 2012-11-12 6:58 PM
My Hawg Wired amp is tightly squeezed on top of the left fuel tank and it is smaller than the RF PBR300X4. So my guess is it will not fit.
Posted 2012-11-14 10:15 AM (#126740 - in reply to #126695)
cw1115 - 2012-11-13 6:35 PM
Baadawg, I have finally made up my mind on Polk MM521 speakers. I really want to do the RF amp. The MM521 are 15-90W peak of 200W, marine certified. .
I'm running the Polk db521 speakers and they sound great and get very loud but stay clear using the RF PBR300X4 amp. They are marine certified so they're perfect for the bike. They cost about $89/pair.
I've mounted my amp in the same location as badawg and have cut an opening in the saddlebag behind the amp. I have a small pancake computer fan mounted in the front cubby of the saddlebag blowing directly on the amp. It still runs hot but hasn't fried yet. I have the fan come on whenever the bike is running (it's not switched with the radio).
My problem is that once the amp turns on (senses signal at its input), it doesn't turn off even if the radio is then turned off. The amp stays on, building up heat until the bike is shut off. Anyone else have this happening? I've corresponded with Fosgate support and they say the amp needs to see a 6volt offset to power on/off. Not quite sure what that means.
Riverdawg
Posted 2012-11-14 1:51 PM (#126752 - in reply to #107439)
Camas Washington
I don't get a lot of what some of you are saying. On a bike the only thing an amp will provide is more power to the speakers. Throw pure clairity out the window do to all the wind, engine and pipe noise, do you really think you are hearing all the highs and lows these amps provide like they would in a car? My son has a degree in sound engineering and he laughs at the mods people do. Your riding a fricken bike your not in a Lexus car. I took his suggestion, bought the Alpine amp (cheap cost $99) to drive the speakers and provide a minor improvement in clarity, but this is mainly do to the power increase. The Alpine fits very nice in the rear hole under the trunk area. It also kicks almost no little heat so no fan required. I'm just saying, if you feel better by spending a ton of money and fooling yourself, have at it.
baadawg
Posted 2012-11-14 5:53 PM (#126764 - in reply to #107439)
Chattanooga, TN
Riverdawg, your objectives and reasons may not be the same as someone elses. So get off your high horse! I'm not criticizing your choice of Alpine, am I? It's your ride, your choice. If you don't like choice, don't come to an online forum like this. Just hand the dealer/business of choice your money and tell him to give you what he thinks you should have. This a place to discuss ideas for improvements on our common interest, Victory Motorcycles.
That said, I chose Rockford Fosgate due to it's low energy requirement. It is the amp of choice for electric vehicles. I may have paid a little more than you did, but not by too much considering that I am doing my stator a favor. Maybe the battery too if I listen to it in the garage without a charger on it at the time. I also have hearing loss due to an accident when I was a teenager. Hearing aids are several thousand dollars per ear for the ones that will help me the most, and nothing will take away the loud and constant ringing in my ears. I can hear just fine on the forum, in real life people can speak up a little and an amplifier with speakers that can handle the power trumps the hearing aids with weekly battery changes. Now, the radio is the way I like it, I'm happy with it and if I can help someone else out with theirs, I will. I'll also feel good about it while you'll still be a blustering mouth breather.
baadawg
Posted 2012-11-14 7:38 PM (#126782 - in reply to #107439)
Chattanooga, TN
It seems I got my knickers in a twist. If you'll please excuse me..... After my knee surgery I haven't ridden much and am suffering from PMS. I hate parked motorcycle syndrome.
Monkeyman
Posted 2012-11-15 2:43 AM (#126808 - in reply to #107439)
Peru, IN
As I plan on wearing my modular helmet most of the time, I think I'll start out with a decent BT headset (and all the expensive Vic stuff to make it work) first. I'll probably add an amp and better speakers later.
Riverdawg --- Increased power is exactly what it's supposed to do. Volume stays lower but the speakers can be driven to their maximum potential before they distort. A good amp (especially with some better than stock speakers) will sound much better (clarity) than no amp. The stock radio isn't very strong. Most of them aren't. With my helmet on, I can't clearly hear the radio without cranking it up so much that it's terribly distorted. With an amp, I could hear it better.
Riverdawg
Posted 2012-11-15 1:22 PM (#126839 - in reply to #126808)
Camas Washington
My point is for those who are considering an amp, if you think a highend amp will make the sound quality equal to or close to what you get in a car, that won't happen. An amp will drive the speakers with more power which increases the sound, it also allows you to have a much better speaker were the driver can handle the power without blowing, that is were the improved clarity will be, in the upgraded speaker. Thus a cheaper power amp + a high end speaker = much improved sound. Spend the money in speakers not the amp.
Posted 2012-11-15 1:39 PM (#126840 - in reply to #126839)
Riverdawg - 2012-11-15 2:22 PM
I don't buy it. The RF amp is about as cheap as you're going to find while still delivering decent THD and S/N ratio. Cheaper amps will easily be driven to distortion at the levels we need going down the road. It doesn't require having a background in audio engineering, which I do, to hear distortion from cheap amps thru high quality (or low quality for that matter) speakers. Amp specs play a very important part in the quality of sound even in a noisy environment.
cw1115
Posted 2012-11-15 3:41 PM (#126845 - in reply to #107439)
Ruskin, Fl
Jeff, I have an engeering question than. The MM521 speakers are 2.7 ohms. They claim they are "(compatible with virtually all factory or aftermarket car stereos)". I plan on running the amp at 4 ohm. I am also confused by the 15-90W power range. Does that mean it takes a min. of 15W to drive these? I was planning on the amp down the road. How will that work with the stock radio only putting out a 23W max?
Here are the specs:
Highlights:
5-1/4" 2-way speakers (pair)
woven honeycomb glass fiber composite woofer cone with butyl rubber surround
1" silk composite dome tweeter with swivel mount
certified for marine use
2.7-ohm impedance for extra power (compatible with virtually all factory or aftermarket car stereos)
power range: 15-90 watts RMS (200 watts peak power)
frequency response: 50-25,000 Hz
sensitivity: 92 dB @ 2.83 V
top-mount depth: 2-3/8"
warranty: 1 year
Thanks
Edited by cw1115 2012-11-15 3:42 PM
baadawg
Posted 2012-11-15 9:43 PM (#126884 - in reply to #107439)
Chattanooga, TN
Michael, I know you asked the Jedi a question, and noticed one potential issue IF you are still planning on the RF amp. It is for 4 ohm speakers only. 2 ohm speakers will fry it like a side of bacon. I guess that is part of the efficiency of the amp. Others have said that they didn't experience any issues with a lower ohm speakers and the factory radio not matching exactly, but with that particular amp it could be an issue. I'm no engineer, so that's all I've got. Good luck.
cw1115
Posted 2012-11-15 10:16 PM (#126888 - in reply to #107439)
Ruskin, Fl
Thank you for the input. I may call Polk's tech line tomorrow. Always plan "B". DB521s and the Alpine amp.
