2011 and Popping
viclvr
Posted 2011-12-19 10:18 AM (#103668 - in reply to #73379)
Subject: Re: 2011 and Popping
Princeton, MN
I have S1 L2 with recored Atom Bomb mufflers and Lloyds intake plate and have nearly eliminated any pops with my VFC III,, it works great! Only ones I can get are fabricated by really jockying the throttle.
opas ride
Posted 2011-12-19 6:32 PM (#103688 - in reply to #73379)
2011 Silver/Black Vision with S1L1 and factory/dealer install...No pops as yet with 3000 miles...08 Kingpin with Stage 1 popped and cracked, etc. etc. like a old car with holes in the mufflers and bad plugs.... Got so bad the guys had me ride at the rear of the pack...Loved the bike and hated the noise......
wingit3611
Posted 2011-12-19 6:48 PM (#103690 - in reply to #103594)
Subject: RE: 2011 and Popping
marcparnes - 2011-12-17 8:35 AM Rick Farrar - 2011-12-16 9:00 PM
Marc:
???? The assembly is just behind the triangle on the rite side.? Two hoses "T" and attach to it on the?side away from the air box & one on the other side going to the air box on the air box side
Rick, I think you're referring to the Idle Air Control valve. This is standard on all the bikes. It controls the amount of air that is allowed to bypass the throttle plates in order to maintain the correct idle speed. Lloydz valve which I installed, further regulates the amount of air which is supposed to limit popping. The surge you feel at 1800 rpm is not a function of the valve as much as from the fuel being turned back on by the ECM. I installed Lloydz's valve in order to reduce the surge for which it did in fact help. I'm curious about the plastic screw you found. I don't see that. Thanks, Marc
Marc:
I'll try to get a picture of it and try my luck at adding it to a message. I still don't think I get my quotes in my
replys rite yet.
wingit3611
Posted 2011-12-25 6:50 PM (#104089 - in reply to #103690)
Marc:
Got my picture of the grey knob at the IAC connection. It's got screw threads on it.
wingit3611
Posted 2011-12-25 6:55 PM (#104090 - in reply to #103690)
Rick Farrar - 2011-12-19 7:48 PM marcparnes - 2011-12-17 8:35 AM Rick Farrar - 2011-12-16 9:00 PM
Marc:
Marc:
replys rite yet.
I got the picture but it didn't load the first time (operater  trouble)
marcparnes
Posted 2011-12-25 6:57 PM (#104091 - in reply to #104089)
Rick Farrar - 2011-12-25 3:50 PM
Marc:
I'm anxious to see that pic if you can get it posted.
Marc
wingit3611
Posted 2011-12-25 7:28 PM (#104093 - in reply to #104091)
marcparnes - 2011-12-25 7:57 PM Rick Farrar - 2011-12-25 3:50 PM
Marc:
I'm anxious to see that pic if you can get it posted. Marc
I got it down to 100k (learned some  thing new tonite). here goes! if it don't work E-Mail me at wingit3611@aol.com  subject IAC
(IAC(1).JPG)
Attachments IAC(1).JPG (97KB - 10 downloads)
marcparnes
Posted 2011-12-25 7:58 PM (#104097 - in reply to #73379)
The grey "knob" you're seeing is actually a cap similar to a tire valve cap. Its covering up an access port to the fuel injection line. It is a fitting used to check the fuel pressure in the system. Oh well :-)
Marc
wingit3611
Posted 2011-12-25 8:01 PM (#104098 - in reply to #103600)
kevinx - 2011-12-17 10:39 AM Louder the pipe....Louder the pop. Vic uses the IAC as an air injector, and unless they change that. The pop is going nowhere
Here is a picture of my California factory IAC!
(IAC(1).JPG)
Attachments IAC(1).JPG (83KB - 3 downloads)
marcparnes
Posted 2011-12-25 8:07 PM (#104099 - in reply to #73379)
That's not your IAC Rick. The IAC is the part right below the one you show in the picture. It has an electrical plug attached to it.
Marc
kevinx
Posted 2011-12-25 9:04 PM (#104104 - in reply to #104098)
Rick Farrar - 2011-12-25 9:01 PM
Like Marc said........That's your fuel line
wingit3611
Posted 2011-12-26 10:34 AM (#104122 - in reply to #73379)
marcparnes - 2010-11-12 4:18 PM I just realized that my new '11 doesn't pop back through the exhaust like the '10 did. 1500 miles and it hasn't popped even once. They must have fixed something. Marc
Glad somebody can keep me strait, there goes my credability. Can't answer on page two after I put that fussed up picture on page two, no quote or reply show on that page any more. Thanks guys.
kevinx
Posted 2011-12-26 10:52 AM (#104125 - in reply to #104122)
Rick Farrar - 2011-12-26 11:34 AM
Pic was so big; you have to scroll WAY to the right to see the reply buttons
Mike
Posted 2011-12-26 8:27 PM (#104150 - in reply to #73379)
East Haven, CT
Stock 2011... no poppig ...1300mi
Posted 2012-08-04 11:55 AM (#120855 - in reply to #104150)
I had a interesting little issue with POPPING on my 2011. well a few days ago I was getting popping that was getting worse and worse as each day went by.. Then I started to notice my idle was a little low and bouncy.. all I did to correct this issue to date was? Unplugged that IAC turned the bike on and waited for the check engine light to come on.. then I connected the IAC again and then turned the key so that you can hear the IAC. Then you turn the bike off and wait 5 second.. you do this 3 times and it makes the IAC re-learn its function.. so far 3 days now and it idle @ 1000 or slightly above and the popping is 98% gone.. all just from doing that?
Edited by Arkainzeye 2012-08-04 11:56 AM
MaddMAx2u
Posted 2012-08-05 9:08 AM (#120925 - in reply to #73379)
Orlando, FL
I have always assumed the popping everyone talks about is on deceleration. Mine pops from time to time and I actually kinda like it. So, I've never understood all the fuss about it. If I wanted no popping and everything all smooth and shitz I would have bought a wing. A V-twin has it's own idiosyncrasies that will always be there.
Just sayin'
Edited by MaddMAx2u 2012-08-05 9:09 AM
GTwo
Posted 2012-12-28 11:02 AM (#128881 - in reply to #73379)
Arkainzeye...I think you are on to something here. I have had problems with surging, coughing, and dying. I just disconnected the IAC and started. The check engine light came on. I turned off the bike and pushed the plug in and pulled it out several times to knock off corrosion, if any. I then re-started and it ran more smoothly. I turned off and re-started a few more times and slowly turned the throttle and the rpms up a few times. Seems more smooth all around! This just might be the gremlin that has been harassing me for a few weeks. I'll report back after a while.
Note that one of my vehicles is a Jetta TDI and I have to disconnect and reconnect the MAF connector several times once or twice a year. It is as if corrosion builds up on the connector and interferes with the operation. Electrical devices often operate on very narrow volts/current/resistance and if they drop out of range they do not function properly. This was the case on my Jetta. It would run crappy. I then open and close the connector a few times and boom, everything is perfect again. Same thing used to happen on an old computer. I would have to re-seat a few of the cards on occasion and the glitchy operation would go away.
GTwo
Posted 2013-01-07 10:02 PM (#129302 - in reply to #128881)
No joy. According to KX pulling the plug on the IAC until you get a CEL and plugging it back in forces the ECU into a learn mode. However if the IAC has a problem the issue will likely return, which in my case did. The issue is still a bit random but after checking and cleaning, and snugging up every thing electrical, I still have the surging at idle about 50% of the time. The good news it is not as severe usually. Next step is to go to the dealer and have him install and new one under warranty.
norcan
Posted 2013-01-07 11:40 PM (#129307 - in reply to #73379)
Edmonton Alberta, Canada
I will post on this thread......3 years ago my popping was really bad! I was kinda just living with it. How ever one day I took in a radio station gas give away. I always ran Shell fuel on all my bikes. However this radio station was running their fuel give away through 7-11 convince stores. I latter found out that their fuel came from Petro-Canada refinery. Long story short, as soon as I changed brands of fuel the popping disappeared. Even my co-pilot noticed the difference. I was skeptical at the time as I always believed shell had the highest requirements for their fuel. a couple times since I have had no option but to fuel up at Shell as I was in a remote area, and the popping would return almost immedi atly. I have always said start with the most obvious this tinker deeper.
