Good Parts Source for Clutch Slave Cylinder
ltrmc02
Posted 2017-10-16 8:44 AM (#192299)
Subject: Good Parts Source for Clutch Slave Cylinder
NC
I'm in need of a new clutch slave cylinder or a rebuild kit for my 2008 Vision. I've found the cylinder on-line for $104 but if anyone knows of a place I can get one for less or a seal kit to rebuild mine I'd appreciate that info.
twocell
Posted 2017-10-19 3:57 PM (#192302 - in reply to #192299)
Subject: Re: Good Parts Source for Clutch Slave Cylinder
Lackawaxen PA United States
i see there hasn't been any real response not that I know of anything but the advertisers on this site might be of help ... witchdoctor's are absolutely great & of course Lloydz as well I'm sure you could find out something from eiter one of those sources
mokintner
Posted 2017-10-20 4:49 PM (#192303 - in reply to #192299)
Austin, IN United States
I took the one on my 08 Vision apart and clean it up, replaced the brake fluid in the clutch system this spring. No trouble with the clutch after 10,000 miles.
Don07tncav
Posted 2017-10-20 7:40 PM (#192304 - in reply to #192299)
The Indian part number is the same. Also I read where a guy had found the same one on eBay a lot cheaper. Looked but never found any.
