fuel processor & digital read out (mpg)
Posted 2009-05-06 5:57 PM (#33963)
Subject: fuel processor & digital read out (mpg)
i have been wanting to ask for a long time now. but i always forget.. If you install a fuel management device. (any brand) and if you HAVE TO disable the o2 sensors, do you loose the Mile per gallon readout on the screen where the gear indicator is?
Posted 2009-05-06 6:19 PM (#33965 - in reply to #33963)
Subject: Re: fuel processor & digital read out (mpg)
i was also just wondering if you disable the o2 sensors does it ALSO disable that feature on the digital read out where it says, how many miles you have left to your tank of fuel?
mkultra
Posted 2009-05-07 8:33 AM (#33992 - in reply to #33963)
Tucson, AZ
I had a Power Commander put on mine, the O2 sensors still connected, and all reading still function. I questioned leaving the O2 sensors connected as i always disconnected on my harleys and used the resistor dummy plug on the wires but my dealer said that was the Harley....this is the Vision. So i dont know if it is good or bad, but do know it runs well and fuel mileage has increased about 2 mpg overall.
mike
stumpy
Posted 2009-05-07 9:44 AM (#33995 - in reply to #33963)
Cabot Arkansas
No you do not lose the reading it might be off but we all know that it is off from the factory (the reading it displays vs miles per gal). I have installed the Lloyds fuel controller and airfilter i have also seen an increase in fuel mpg on the readout. hope this helps
