More headlight issues
witchbiker
Posted 2017-12-06 12:54 PM (#192364)
Subject: More headlight issues
Jedi, et.al.,
What supports the reflective headlight housing, and keeps it from shaking with every bump? The only thing I can see to keep it 'solid' are the rubber dust boots. Without those, it seems that the housing is free to bounce around all over the place, making the headlights only survive about a week....maybe!! Must've missed some clips or screws somewhere!!??
witchbiker
2008 Vision Tour w/only 90K
'Black is the new Chrome'
BumbleDB
Posted 2017-12-06 7:10 PM (#192365 - in reply to #192364)
Subject: Re: More headlight issues
It has to be attached to the adjustment wheel and at least one pivot point. The housing does not adjust, so it must be the reflector plate that moves.
Posted 2017-12-27 11:33 AM (#192369 - in reply to #192364)
Subject: RE: More headlight issues
witchbiker - 2017-12-06 12:54 PM
Jedi, et.al.,
witchbiker
not sure what your saying. The headlight is mounted in all 4 corners. If the reflective houseing is moving I'm guessing the inside of the light is loose and the only way to find out is pull the hole headlight and inspect it. If you look for a use one there not checp maybe $300 bucks. Tell us more about what you mean is loose
Posted 2017-12-27 11:53 AM (#192370 - in reply to #192364)
are you reflector to the reflector on the HID light. If so I have read where others have had this happen. They pull the light and snap in back in place
