Rear Brake Rotor (disc)
Crawford
Posted 2016-06-24 1:33 PM (#184974)
Subject: Rear Brake Rotor (disc)
Regina Saskatchewan Canada
Has anyone every had to replace their rear brake rotor because it became loose on the floating pins? I've had to replace two because of this problem.
Posted 2016-06-24 6:23 PM (#184978 - in reply to #184974)
Subject: Re: Rear Brake Rotor (disc)
I have read where guys have put a bolt thru the button add washers and nut now tighten it up.
You could be using the rear for stopping when its designed to slow you down. Front stops you
Posted 2016-06-26 5:28 AM (#184984 - in reply to #184974)
I had to replace my rear rotor on my 2008 when it was 3 years old for the same reason.
https://youtu.be/tRPaUyXrtbE
Posted 2016-06-26 9:53 AM (#184997 - in reply to #184974)
Subject: RE: Rear Brake Rotor (disc)
You mean, like this?
