106 Flywheel puller size?
ShowTime56
Posted 2015-02-02 5:20 PM (#169664)
Subject: 106 Flywheel puller size?
Hi guys, first post on this forum and am in a pickle. Need to pull my flywheel off to fix the one way starter clutch on my Vision. Anyone know what exact size puller I need. I have tried 18mmx1.50 and that is too small.
Thanks,
Show
Posted 2015-02-02 5:39 PM (#169666 - in reply to #169664)
Subject: Re: 106 Flywheel puller size?
I don't under stand pulling flywheel
(starter.gif)
Attachments starter.gif (36KB - 0 downloads)
ShowTime56
Posted 2015-02-02 6:44 PM (#169669 - in reply to #169664)
Subject: RE: 106 Flywheel puller size?
Behind the flywheel lives a split gear setup. Between the two split gears is a one way starter clutch assembly that provides the contact to the crank portion of the split gear. My one way clutch busted from a serious buck or backfire during cold weather start up.......................... Item 12 is the idler gear which provides the rotation from the starter to the split gear I am talking about. You have to pull the flywheel to seperate the split gear assembly............
Show
Edited by ShowTime56 2015-02-02 6:47 PM
tonyj
Posted 2015-02-03 8:30 AM (#169676 - in reply to #169669)
Salina, KS
I would give Rylan a call at The Vic Shop, he is a super nice guy and would be able to give you all the info needed for your repair.
