vision fork interchange ?
jb.hatch
Posted 2012-12-24 8:47 PM (#128780)
Subject: vision fork interchange ?
Phenix City AL.
My wife got me a used front end, forks with tripple trees , for christmas, but they have for 08 only written on the trees, I have an 09. The plan is to powdercoat the lowers, rebuild the forks, then sawp them out for the ones that are on now ( nothing wrong with the ones I have , just do not want the vision to be down while getting powder coat and fork rebuild) Soooo what is the difference between 08 and 09 ???? After the swap I was going to sell or trade the front end I take off ( I will be looking for break calipers next , I am going with the conquest red calipers) I might have to sell the 08 set if they will not fit.
V92SC
Posted 2012-12-24 10:15 PM (#128781 - in reply to #128780)
Subject: Re: vision fork interchange ?
New Orleans, La,
Someone else may want to chyme in with verification but I read somewhere that the forks are interchangable. The differences are internal between the 08 and subsequent model years making the 08 more difficult to break down.
kevinx
Posted 2012-12-26 11:57 AM (#128818 - in reply to #128780)
What you need to do is look for the letter M cast on the 09. If it is there then the 08 is a direct swap. If it is not there; then the 09 has KYB forks, and the tube is 1mm bigger then the 08
Posted 2012-12-26 6:22 PM (#128831 - in reply to #128780)
I think 08 is 43mm and 09 is 44mm
You should use the 08 trees and forks as one. Other then that no big difference. Check a parts book. You'll need new bearings and buy them from a bearing store you can get better ones at a cheaper price
