OK- help a non techie- delaminating throttle body gasket ?
hottierod
Posted 2012-04-27 10:48 AM (#113079)
Subject: OK- help a non techie- delaminating throttle body gasket ?
Sturbridge, Mass
Got bike back from shop, had been running very rich- lots of black soot , very poor MPG ( 30-32) and sluggish response.
Dealer fix was replacing throttle body gasket- delaminating and allowing an air gap issue. Also, battery issues was not fully recharging so ECM was compensating.
Anybody else have the throttle body issue ?
kevinx
Posted 2012-04-27 8:41 PM (#113117 - in reply to #113079)
Subject: Re: OK- help a non techie- delaminating throttle body gasket ?
Throttle body adaptor failure is not that uncommon
RedRider
Posted 2012-04-28 9:16 AM (#113143 - in reply to #113079)
On the older bikes Barry Twowheels sold a replacement TB gasket because they had problems with the gaskets a lot. I haven't seen it on the newer bikes. Gaskets are man made so anything can happen.
Kind of like I am the only person I know that had the rear wheel crack at the rim in several locations. Ext warranty covered it after a go around.
Vicbuilder
Posted 2012-04-28 10:57 AM (#113149 - in reply to #113079)
The Vic Shop - Central Iowa
I keep two in stock at all times it is so common. BTW it is not the gasket, it is the throttle body adaptor itself that delaminates.
