Trunk turn and stop lights
rodog
Posted 2008-11-22 8:10 AM (#23713 - in reply to #23296)
Subject: RE: Trunk turn and stop lights
Shelby Twp. MI
Ok were did you do your taping in to the system at...do you have the wire. Colring code for what is what. And so on for all us...
wrr1home
Posted 2008-11-22 9:43 PM (#23740 - in reply to #23713)
Don't have a clue!
I know the module ended up under the seat, but the dealer installed it for me and did what wiring was necessary.
TimS
Posted 2008-11-24 12:22 AM (#23832 - in reply to #23558)
Subject: Re: Trunk turn and stop lights
The replacement lenses do not cost that much, @ $25 each.  I tried the alter bulb thing and it melted the housing, thus bought replacements.
 This housing was not designed for a dual element bulb's heat.  To make the running lights into turn/brake, LEDs need to be used.  It would be nice if these lenses could be taken apart, but they are glued together.
HTH,
Tim
TimS
Posted 2008-11-24 12:29 AM (#23833 - in reply to #23713)
rodog - 2008-11-22 5:10 AM Ok were did you do your taping in to the system at...
The turn signal controller harness is located under the console by the ignition switch.  If you have the service manual, it shows you the wiring diagrams and the pin-outs of this harness.  I used this harness to tap the left, right and brake signals to feed the trailer controller.  I then tapped into the switched 12 volt power outlet that is also under the center console for switched running lights.  The trailer controller only pulls a couple of milliamps from each of these 4 lines to power the secondary lights.
HTH,
Tim
I need to lookup the service manual again to see the exact pinouts.
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=1511&start=1&highlight=lights&highlightmode=1
TimS
Posted 2008-11-24 1:06 AM (#23834 - in reply to #23833)
I went out into the garage and got the service manual.  HTH.  It was past 30 minutes so I could not update my last post with this.
The turn signal controller harness is located under the console by the ignition switch.  If you have the service manual, it shows you the wiring diagrams and the pin-outs of this harness. The diagrams are on pages 19.10, 19.11 and 19.12 for this.
PIN #2: 12v Brake Input Power - W/PINK
PIN #8: Right Turn Signal Output - BLUE/RED
PIN #15: Left Turn Signal Output - BLUE
See page  19.23 for switch outlet and lighted badge circuit to tie into for running lights.
slowryder
Posted 2008-11-26 4:38 AM (#23999 - in reply to #23296)
L.I., N.Y.
Tim that an awesome set up. Did you run the side strip inside the hinge seam or is just below the trunk lid's seam.
TimS
Posted 2008-11-26 10:34 AM (#24005 - in reply to #23999)
The trunk, mirror and sidebag lights are all insided the seams with hidden mounting to match the style of the Vision.
Tim
slowryder
Posted 2008-11-30 2:42 PM (#24282 - in reply to #23296)
L.I., N.Y.
Do you remember the kit numbers or parts numbers. I got an email back from Dave at Custom Dynamic and will be speaking to them Monday.
TimS
Posted 2008-11-30 10:16 PM (#24317 - in reply to #24282)
Please read this thread for the parts:
Tools Lists:
Phillips screw driver, metric Allen wrenches, heat gun (shrink wrap), soldering iron, ratchet, sockets and extensions, wire cutters, strippers, crimpers, grinder, tin snips.
Parts lists:
Cheese Wedge Running Lights: 30 LED Stringerz (12 inches) - http://www.customdynamics.com/stingerz_led_accent_lights.htm
Mirror Turn Signals: 9 LED Stingerz (4 inches) - http://www.customdynamics.com/stingerz_led_accent_lights.htm
License Plate LEDs: Knight Rider Non-Sequential LED Bar - http://www.customdynamics.com/knight_rider_led_light_bar.htm
Trunk Brake Light: Radiantz 1' 100 LED Bar - http://www.radiantz.com/cart/index.html?c34.html&1
Trailer Light Controller: DrawTite ModuLite HD - http://www.drawtite.com/118190.html
Trailer Light Wiring Kit: DrawTitle Wiring Kit - http://store.drawtite.com/118151.html
Trailer Light Wiring Harnesses: 5-Flat WesBar connectors
Stop Only Light Controller: 12 volt relay
firehawk
Posted 2008-12-09 10:34 AM (#24750 - in reply to #23697)
College Station, Tx
wrr1home - 2008-11-21 7:28 PM Here is a short video showing brake lights, left signal, right signal & 4 way flashers. Hope this helps! http://www.youtube.com/watch?v=gyteShtlTBg
I got mine working like this last night!!! I took lots of pictures and will be doing an instruction sheet tonight as I put it all back together. It is an involved process because you have to take the trunk lid apart and run a new wire for the left light. Other than that it was not all that difficult to do. It took me 3 hours to get it working from start to finish but I still have not gotten it all put back together yet so you can probably add one more hour to the total time it took me but it should be less with instructions.
TimS
Posted 2008-12-09 10:47 AM (#24753 - in reply to #24750)
FireHawk,
Please repost the URL, it is mal-formed.
It works if you cut-n-paste, but not if you just double click.  Results look good.  Let us know what you used to get the trunk lights working.
Thanks,
Tim
Edited by TimS 2008-12-09 10:50 AM
firehawk
Posted 2008-12-09 10:49 AM (#24754 - in reply to #24753)
College Station, Tx
Sorry it was a quote from wrr1home's post on page 1 of this thread. I will be doing instructions and a video of mine asap.
Edited by firehawk 2008-12-09 10:51 AM
Posted 2008-12-09 3:52 PM (#24756 - in reply to #23296)
firehawk,
Thanks in advance for the post. I am looking forward to spending some Christmas money to add this feature on Sparks.
