New Tires
spursmvp
Posted 2009-04-28 10:18 PM (#33383 - in reply to #33364)
Subject: RE: New Tires
O'Neill, Nebraska
Codfather - 2009-04-28 5:48 PM
Spursmvp, I would have new tires for that trip as the route is not paved that well. That is not a good place for tire problems!!!!!!! BL
Thanks for the tips guys! I'm taking the Vision in for some Warranty work tomorrow (shift indicator switch) and I'll have them look at the tires for me.
Spock
Posted 2009-04-28 10:30 PM (#33385 - in reply to #33274)
Carrollton, TX
I put over 45,000 miles the Metzeler ME880’s on my on my last bike and while they were good tires when I tried the Dunlop Elite III’s on my last bike I was sold. The Dunlop Elites wear better than the Metzelers and they grip just as good and I thought the Dunlop’s handled better in the rain.
I have friends that have Gold Wings and they have used the Dunlop Elite III’s, Metzeler ME880’s and the Avon Cobra’s and almost all of them like the Dunlop’s the best. My friend Fergy tried a set of the Avon Cobras on his Vision and while they were not bad they did not wear as well as the Dunlop’s and did not handle any better but cost more.
Another good thing about the Dunlop’s are most every Gold Wing dealer keeps these in stock and the Metzelers and Avon’s will be a hit and miss.
On the mileage side I have found the Dyna Beads make a big difference and I will use these from now on. http://www.innovativebalancing.com/motorcycle.htm I ride my bike fast and hard and usually only get about 8,000 to 9,000 miles on my rear Dunlop Elite III tires but with the Dyna Beads I am getting 12,000 to 13,000 miles on the rear and the balance is noticeable better. So for me the best tire solution are the Dunlop Elite III’s with the Dyna Beads.
Posted 2009-04-29 4:07 AM (#33391 - in reply to #33385)
Again I am reminded of the Dyna Beads and still haven't used them yet. I should be swapping out tires here soon and will have to give them a go.
As for tires, I respect everyones personal opinion on what they use and their personal experience. It's good we can share input on the difference of how the Vision rides, but I think the tires are the personal choice. If the person finds a Metz, Avon, or Dunlop works better for them in ride experience, let them make that choice. If I was to try the Avon and find they did better than the Dunlop, but only got 10K out of them verses 15K as I do with the Dunlop, I would go and stay with Avon regardless how anyone else felt about it, it is my ride experience I am after.
For me the Dunlop's have not given me a reason to find a "better" ride experience as they have performed very well on "the edge of the road" experiences in the twisty and gave me full confidence I was in control and they were doing there job. I've also ridden in hard down pours, nose stuck in the windshield to see downpours and be doing 70 mph's and didn't even know I was going that fast, they pushed the water away very well.
It is only when I get down to the last 1,000 or so miles left that there is an issue, as I'm probably pushing the envelop there to squeeze every drop out of them. But as long as the forcast is dry, I will continue to ride them out, or ride with extra caution, as even then they still out perform the continentals that I've ridden on with my Wing. I notice those tires never end up in these discussions.
VisionTex
Posted 2009-04-29 5:27 PM (#33433 - in reply to #33381)
Subject: Re: New Tires
LaPorte,Tx.
Dunlap E3 for me.
Excellent mileage, 12 to 15K on rear, front 20K
Low cost, I can get the rear for $237.50 installed.
Excellent grip, wet and dry, enough to grind off the bottom of the boards.
Higher Index rating on rear, 80H, the 180 60R-16 is load rated at 992 lbs. WOW!
Available, you can get them many different places.
And they are made in the USA! Keep the boys at home working.
Teach
Posted 2009-04-29 6:45 PM (#33439 - in reply to #33172)
I've never had good luck with Metz on any bagger Honda or Harley so you wouldn't catch me putting them on my Vision. I've had sidewalls crack, flats, and a number of other issues with this brand. They also don't offer great traction on cold roads. The Avons are usually a great tire BUT if you go to the GW sites you'll see a lot of folks moved away from them due to a high speed separation issue. Since they cost and are designed almost exactly the same as the E-3 no point in swapping.
As to the Dark Side tire? Well I was giving that some thought myself until I had my rear tire develop some issues. I rode them out after a repair was made to my rear shock but the tire developed a premature flat spot in the center. Riding the Vision with the center of the E-3 flattened convinced me a darkside tire was out of the question. GW riders mention the same which is why most don't go Darkside. Lots of riders reporting 14-15k on the rear E-3 just sealed that deal for me.
I guess folks will decide what is best for their situation as they should.
devilboy
Posted 2009-04-29 6:56 PM (#33441 - in reply to #33439)
Central Florida
Got the Metzelers on today and off on 2.5K trip tomorrow am.
The E3s had 2 screws in them and center of tire was gone. cords were showing in two places.
front was fine(7500 left) but I changed the front and back together.
first impression is better grip and smoother ride but it is too early to say.
Paid $310 delivered for them from Motor-cycle superstore.
I also had the drive belt replaced today as it had some moderate chipping.
Every 14th tooth was chipped and belt probably could have gone another 30K at minimum.
there was a small rock in rear pulley corresponding to the chipped teeth.
I kept the belt for backup!
off to Tennessee tomorrow and Monday to Louisville KY for trade show..
Gainesville next Friday to get the 30K service including front forks done by the Jedi Master of wrenchdom KevinX..... and then home.....
Edited by devilboy 2009-04-29 6:57 PM
Teach
Posted 2009-04-29 7:00 PM (#33443 - in reply to #33172)
Sounds like fun, enjoy the trip
Teach
Posted 2009-04-29 7:01 PM (#33444 - in reply to #33172)
spursmvp
Posted 2009-04-29 8:41 PM (#33449 - in reply to #33172)
O'Neill, Nebraska
Just got back from dropping the Vision off at the dealer for warranty work. When he looked at the rear tire, his comments were "You obviously have been paying attention to the air pressure." Even with 9k on the rear, the service manager told me that I had at least 3k left on the rear E3...guess I'm fine with it until I get back from California.
cjnoho
Posted 2009-04-30 1:45 AM (#33458 - in reply to #33172)
So Cal
I've tried all kinds of tires trying to get the best milage. Dunlop seems to be the best compromize. With a heavy touring bike 12k is about the best I can do and Dunlop has always been my choice. I have come to realize that better wearing tires are possible but grip suffers. Most of the time you dont know your tires dont have enough grip till its too late.
kenhiggins
Posted 2009-05-02 7:53 AM (#33638 - in reply to #33172)
Montreal, QC Canada
Had the Dunlops put on yesterday. Had a good look at the rear tire and it would seem that 17,000 (s)miles on a tire is TOO MUCH. There weren't even any wear bars left. The front still had a few thousand miles left but I changed it out anyway. As long as its on the bench, do the work. Both front and rear brakes have only worn down about halfway. The wrench says I certainly got my moneys worth out of these tires.
Devilboy, can't wait to hear how you like the Metz's. Lets see how they are in 10,0000 (s)miles.
savage
Posted 2009-05-02 8:19 AM (#33641 - in reply to #33172)
I have always had 900 lb. touring bikes and ride two up 75% of the time. I have used Dunlops (OK), Bridgestones (really suck) Metzler ME88 and 880's (better) and Avon Venom (the best in my opinion). The Avons do not cup, have excellent grip and wear better than the others. I don't do burnouts but I use the torque of the Vision a lot (it's addicting) and ride aggressively in the twisties.
Just my 2 cents!
Edited by savage 2009-05-02 8:20 AM
