green Neutral light
Posted 2010-06-24 7:33 AM (#63025 - in reply to #57763)
Subject: Re: green Neutral light
Teach - 2010-04-17 3:14 PM
Here is the link: http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmc...
See; S5.2.2, & Table 2 column 3
CFR 49 is something you should familiarize yourself with if you have time. Covers a lot of stuff that is handy to know if you tour a lot.
Thank you Teach!!! i just had my entire dashboard replaced (speedo) With no hassle and no one from victory wanted to even see my bike! I mentioned to the dealer that i heard its a federal law that this light must work. He completely again and put up NO fight at all.. I wanted to say thank you for arming me with the Info needed..
on a side note, when i replaced the speedo all my mileages say ZERO.. i thought that was normal with a analog guage, i didnt know it was the same way with a digital one as well.. for some reason i thought all the info was storage in the bikes Ecu? now i havent ridden it yet so....
yoyo
Posted 2010-06-24 9:46 AM (#63036 - in reply to #56104)
Subject: RE: green Neutral light
ESCALON CA.
most GM odometers get programmed before installation, i did a Ford that came with a door jamd sticker for the previous odometer reading.
Posted 2010-06-24 10:55 AM (#63041 - in reply to #56104)
Hmm interesting.. I wonder if victory is that advanced? i didnt ride it yet. but just starting it up and going through the settings (on the left handlebar switch) shown all ZERO's.. all my friends i told this joke i have a NEW 08 vision.. lol but id rather have it back the way it was.. I am glad to have that GREEN N back!!
Posted 2017-09-27 7:45 AM (#192276 - in reply to #57570)
This thread is over seven years old.
My green neutral light went out. I was wondering if any of you have wired up a seperate green neutral light?
Below I quoted charbin.
Posted 2010-04-15 8:21 AM (#57570 - in reply to #57566)
I just checked on the part number for this sealed unit containing the green N - turns out that the entire Instrument Cluster (3280511) must be replaced as a unit (includes speedo, tach, volts, trip computer, all indicator lights, etc), and it retails for $787.32.  No wonder they denied my claim...
I'm now thinking seriously about simply drilling a hole off to one side of the dash, installing a weatherproof green led lamp assembly, and moving the neutral signal feed over to it.
lennyb
Posted 2017-10-01 6:22 AM (#192281 - in reply to #192276)
Perry Hall, MD
I have not performed this mod, but if there was a way to trace the power source for the light I would be looking for a thin stick on light board to mount over the original N location.
Good luck.
BTW images on your prior post are no longer available. Says your photobucket account needs to be updated.
Posted 2017-10-01 12:51 PM (#192282 - in reply to #56104)
The green (N) is part of a circuit board. , it's not a individual wired light. I know when I started this thread 7 years ago for my 08 vision
The warranty company didn't want t o pay for it.. that was until the dealer said ..if this light came on the bike . It MUST work for state inspection ... and because of that.. it forces the warranty to replace the entire dash , as my bike was then deemed Not legal to be on the road because of it bei mg required to work .
Posted 2017-10-08 11:06 AM (#192290 - in reply to #56104)
mine jumps from 1 to 2 or even 3 am guessing its the wire in the connector that is screwed up
Posted 2017-10-08 11:07 AM (#192291 - in reply to #56104)
lennyb
Posted 2017-10-09 9:03 AM (#192293 - in reply to #192291)
Perry Hall, MD
The dealer repaired the same issue 2x on mine while still under warranty. Reportedly it is a common problem, and they replaced a plunger in the gear indicator switch assembly to fix it.
