Drive belt
V92SC
Posted 2012-07-18 7:12 AM (#119671 - in reply to #46314)
Subject: Re: Drive belt
New Orleans, La,
I recently had my belt gaurd fall off due to the welds breaking during a ride with a bunch of Wings. The broken gaurd got hung up in the belt locking up the rear wheel, damaging the pulley mounted belt gaurd, before causing the belt to come off. I would like to see and here more about the gaurd pictured above, it seems to be a better design IMHO. Are there anymore pics? Does he still post to this site? What's his member handle?
20 10 Vision
Posted 2012-07-18 4:48 PM (#119694 - in reply to #46314)
I believe the picture your referring to is on Rollin's Vision. He made it, or had it made, because he does a lot of IBA riding. His handle is Rollin. Great guy.
Rollin'
Posted 2012-07-18 7:39 PM (#119708 - in reply to #119694)
, WI
20 10 Vision - 2012-07-18 4:48 PM I believe the picture your referring to is on Rollin's Vision. He made it, or had it made, because he does a lot of IBA riding. His handle is Rollin. Great guy.
 Thanks!
 I made the belt guard. Took a lot time, a lot of test fitting.
Brian G
Posted 2012-07-18 8:27 PM (#119717 - in reply to #46314)
Oregon.
Rollin,
What did you attach the piece behind the exhaust to, or is it attached to anything besides the rear sprocket?
Edited by Brian G 2012-07-18 8:32 PM
Posted 2012-07-18 9:03 PM (#119722 - in reply to #46314)
We need better belt gaurds.. not just for rocks. Im in sturgis sd now.. two times now ive had to wash my belt! Due to noise..... tons of dust and little bits of sand all over the belt and little indents in the pulley... it may not be breaking, but its requiring increase maintence due to a lack of coverage of the belt area.. there is even a section in the service manual about cleaning the belt... my hd buddy was shocked how much belt area is exposed....
Rollin'
Posted 2012-07-18 9:30 PM (#119725 - in reply to #119717)
, WI
Brian G - 2012-07-18 8:27 PM Rollin, What did you attach the piece behind the exhaust to, or is it attached to anything besides the rear sprocket?
 It's also bolted to the swing arm. There was a hole in the swing arm, I tapped threads into it and added a bracket to my belt guard.
