You think PARTIAL led lights would look bad?
Monkeyman
Posted 2012-12-11 12:53 PM (#128286 - in reply to #96598)
Subject: Re: You think PARTIAL led lights would look bad?
Peru, IN
They're losing potential customers by the day. I'd love to have a set but there are still a lot of unanswered questions regarding warranty, longevity, replacement parts, etc. Sorry to say but they need to shit or get off the pot.
wrr1home
Posted 2012-12-13 11:53 AM (#128371 - in reply to #128286)
I have the 4710 Kury, hooked up for the trunk lights.
I added 2, 30 LED strings to the edge of the trunk lid running off the trunk lights.
For the "V" I have done the Kansasguardsman mod and have LED bulbs in the lower 4 lights and I left the incandescent bulbs at the top for the factory turn signals.
I also put LED Bulbs in the running lights on the front, with incandescent bulbs for the signal lights. By doing it this way, the turn signals are at normal speed, and I didn't need resistors to slow them down.
Now when I brake, the trunk lights & LEDs flash 3 times then go solid as the 4 lower lights are solid all the time on braking.
My signals work as per factory except when braking, then they flash in sequence from the trunk to the lower ones.
Most folks tell me that it looks good and I can be seen clearly.
Cuaugh
Posted 2012-12-28 10:28 AM (#128878 - in reply to #96598)
Subject: RE: You think PARTIAL led lights would look bad?
sfalexi - 2011-09-14 4:37 PM
I don't really want to have to put in all sorts of resistors and whatnot. So I was thinking about maybe putting LED lights in the turn signals up front, and in the trunk lights (which I have converted to turn signals). This will hopefully be MUCH brighter for people to see during the day (I know the trunk lights are not that bright during the day).
If I left the taillights in the V alone, do you think that (A) it will look wierd having halogen down low and really bright turn signals up high? (you'd only see them if I put on my blinkers), and (B) since the V will still be normal halogen lights, do you think it would then avoid the need for resistors?
Alexi
Have you got led lights of your choice?
Cuaugh
Posted 2012-12-29 12:54 AM (#128900 - in reply to #128878)
Cuaugh - 2012-12-28 10:28 AM
If I left the led taillights in the V alone, do you think that (A) it will look wierd having halogen down low and really bright turn signals up high? (you'd only see them if I put on my blinkers), and (B) since the V will still be normal halogen lights, do you think it would then avoid the need for resistors?
Alexi
Do you have some nice pics of these led lights?
Posted 2012-12-29 12:00 PM (#128913 - in reply to #96598)
I don't think Alexi is active anymore.
