exhaust leak
Victorywldr
Posted 2011-04-14 2:00 AM (#83983 - in reply to #75990)
Subject: Re: exhaust leak
The pipe looks like it has a lot of corrosion and odd discoloration. It sure does look like it split on the weld seam though. You should be ok having it welded. Sure seems like a lot of rust though.
relic123
Posted 2011-04-15 2:53 PM (#84071 - in reply to #75990)
Subject: RE: exhaust leak
Southeast Idaho
picture of the cats.....Called lloyd's and he recomends not to remove
(IMAG0095.jpg)
Attachments IMAG0095.jpg (94KB - 0 downloads)
Cap'n Nemo
Posted 2011-04-15 4:23 PM (#84077 - in reply to #83983)
New Bohemia, Va
Victorywldr - 2011-04-14 2:00 AM
It welded good, but as far as the rust, with 60,000 miles on it I would expect that.
Posted 2011-04-15 4:54 PM (#84081 - in reply to #75990)
Victory has some cheap metal exhaust. I was thinking that the ECM is programed for that cat to be there so if you cut it out I would think the bike would not run good.
mkultra
Posted 2012-08-27 8:51 AM (#122310 - in reply to #84081)
Tucson, AZ
Just had the same crack on my head pipe, just 3 inches lower. Going to try a quick fix with Versachem product so I can ride to Colorado this weekend, then have it welded up when I get back.
mike
