blowing fuse after installing MBW leds front and rear.
raidernine
Posted 2015-04-08 1:32 AM (#171714)
Subject: blowing fuse after installing MBW leds front and rear.
Installed MBW front and rear leds and blowing the signal/brakes fuse a few times over the last year. Press the front brake this week and blow the fuse just sitting in the garage. replaced fuse 20amp and pressed again and no problem. Any suggestions anyone.
Edited by raidernine 2015-04-08 1:32 AM
Posted 2015-04-08 5:49 PM (#171721 - in reply to #171714)
Subject: Re: blowing fuse after installing MBW leds front and rear.
maybe bad switch. Pull switch and look at the wires
Posted 2015-04-08 7:44 PM (#171725 - in reply to #171714)
something is grounding out.. it surely wouldn't be a increase in Load...
