Installing an Alpine KTP455 amp- how ?
hottierod
Posted 2011-01-10 2:28 PM (#76998)
Subject: Installing an Alpine KTP455 amp- how ?
Sturbridge, Mass
Another member is adding the same amp, but has not gotten around to it.
I got the Infinity 5032cf speakers as well, was thiknig of putting the amp in the space between the trunk and rear fender ?
FYI- I will not be doing the install, will be left at the dealers.
Thxs !
VisionTex
Posted 2011-01-10 5:19 PM (#77006 - in reply to #76998)
Subject: RE: Installing an Alpine KTP455 amp- how ?
LaPorte,Tx.
That area might not be the best place as it is not totally water proof. You probably could water proof that compartment. If the amp is water proof should be ok.
Lotzafun
Posted 2011-01-10 5:20 PM (#77007 - in reply to #76998)
Subject: Re: Installing an Alpine KTP455 amp- how ?
Rockford, IL
Don't have any info on the amp.........however have some input on the install.
I'd strongly consider having a good stereo place do it. They are going to be much more familiar with the aftermarket wiring and the proper way to install the amp. And who knows...they might be cheaper than the dealer.
