Temperature Adjustment
Boots
Posted 2010-12-28 8:58 PM (#76309)
Subject: Temperature Adjustment
New Mexico
I believe I have seen this question/answer here, but can't find it.
My temp gauge is about 4deg off, the full range of temp. Has read 116 when it was around 112, and 39 when it was actually around 35.
Is there an adjustment, either mechanical on the sensor or electronically via a menu/offset?
Posted 2010-12-29 5:52 PM (#76331 - in reply to #76309)
Subject: Re: Temperature Adjustment
I have the same problem. 4-5 degrees high. Would love to fix it.
Posted 2011-01-04 6:05 PM (#76655 - in reply to #76309)
So how so you know its off? By the bank clock/temp. If so how do you know there right? Look at all your gauges I'll bet you find them all off.
I know my vision speed-o if I am going slower then what it says maybe thats why I haven't had a ticket. The fuel gauge is close but its off so is
the voltmeter. How do we know are cars are correct? We should look at the gauges as something that give us a general reading and when it changes from what we are used to we should investigate.
Ride and enjoy if it hot it hot and if cold put on another shirt.
