2010 vision foot peg modification??
sonicbluerider
Posted 2016-08-12 7:09 AM (#188121)
Subject: 2010 vision foot peg modification??
, IA
Wife has victory foot pegs on 2010 vision,she only 5'2" and can only use one foot peg at a time, Has anyone modified their pegs to bring them back a few inches .???
lstayner
Posted 2016-08-12 8:17 AM (#188122 - in reply to #188121)
Subject: RE: 2010 vision foot peg modification??
Are you talking passenger pegs or Hwy pegs?
sonicbluerider
Posted 2016-08-12 6:55 PM (#188131 - in reply to #188121)
Subject: Re: 2010 vision foot peg modification??
, IA
The ones on her floorboards--vision is her bike
lstayner
Posted 2016-08-12 8:21 PM (#188132 - in reply to #188131)
I am 5' 9" myself and can't touch the end of the floorboards. She must have really long legs.
In all seriousness, I am not sure you would want to move them back on the boards. It may interfere with her feet reaching the ground at a stop or if she is a canyon carver, you would lose some lean angle.
sonicbluerider
Posted 2016-08-13 7:11 AM (#188137 - in reply to #188121)
, IA
Sorry it's a vision crossbow
Posted 2016-08-13 4:51 PM (#188147 - in reply to #188121)
if it has stock floorboards then yes. Lay on ground and look under floor board is 3 holes. now move to back hole and readjust all linkage and pedals
sonicbluerider
Posted 2016-08-15 8:25 PM (#188200 - in reply to #188121)
, IA
Will look .u talking about holes in rail to move whole floorboards back??
Posted 2016-08-16 5:18 PM (#188211 - in reply to #188121)
did you look in your owner's book. If you don't have one scroll down and put in information
http://www.victorymotorcycles.com/en-us/owners-manuals
sonicbluerider
Posted 2016-08-18 7:33 AM (#188240 - in reply to #188121)
, IA
Nope can't move floor boards, need to find some sort of bracket to screw into foot rest hole that will allow me to run a fitting back 3-4 " to put foot rest on it
Posted 2016-08-19 3:21 PM (#188366 - in reply to #188121)
Get a Ness seat, or a custom one that is 1" lower. Get boots that are 1-2" taller in heel and toe. Sprry, that's all I can come up with.
Posted 2016-08-19 5:45 PM (#188370 - in reply to #188121)
so with out a pitcher of the floorboards we have no way of giving help
Posted 2016-08-19 5:45 PM (#188371 - in reply to #188121)
so I take it she doesn't have stock boards or mounts
olekneedragger
Posted 2016-08-19 7:14 PM (#188373 - in reply to #188121)
Dude, You can slide the floorboards on a Vision two inches forward or two inches back. I came from the sport bike community and still do not like the feet stretched all the way forward riding position of a stock Vision. I moved mine back and the only problem as I can recall is the right push rod for the brakes needs to be shortened (cut) in order to make everything work properly.
olekneedragger
Posted 2016-08-19 7:22 PM (#188374 - in reply to #188121)
Look on the bottom of your floorboards and you will notice two bolts holding your floorboards in position along with a couple of other bolt holes for the forward and rear positions along with a rail that the floorboards slide in. Just loosen the two bolts and slide the floorboards back. It is that freakin simple. Of course, you need to re-position the shift rod and brake rod to allow them to be rotated or else you'll end up with a shifter and brake 1/2 inch off the floorboard, but that is a relatively simple fix. Alternatively, you can bring it to the stealership and part with some cash.
Dain
Posted 2016-09-13 3:55 PM (#188908 - in reply to #188121)
I am Dain with www.victorybrakepedal.com and can make you brake and shifter pedals that bring them closers to the rider. Have done this before for others. Check my site and contact me through there. I am a member here and give discounts to members.
Thanks, Dain
Posted 2016-09-13 5:18 PM (#188909 - in reply to #188121)
show us a photo of the boards
diamonbird
Posted 2016-09-14 6:33 AM (#188910 - in reply to #188121)
The floorboards don't move just the controls are adjustable on the Vision, I do believe!
Posted 2016-09-14 6:04 PM (#188912 - in reply to #188121)
hey take a trip over to the Vic shop have them look at it
http://www.thevicshop.com/contact/
VIII BAL
Posted 2016-09-16 10:37 AM (#188920 - in reply to #188121)
ROSEVILLE, CA United States
Call my buddy Gino and explain to him and i am sure he has a good idea - He "ALWAYS" does 916-725-8158 Him and his family have a Victory dealership in Nor Cal and has helped me design and come up with good ideas for my Vision. He and his buddy Mark have there own line of custom parts as well for Vics called "SYKOTIC INDUSTRIES"
