beads orwheelweights
gary1
Posted 2015-01-05 8:10 PM (#169338)
Subject: beads orwheelweights
im close to putting new tires on just wandering how the dyna beads work any thoughts
Posted 2015-01-05 10:10 PM (#169341 - in reply to #169338)
Subject: Re: beads orwheelweights
ive been using them for years now... you can find youtube videos on this..
Posted 2015-01-06 12:53 AM (#169342 - in reply to #169338)
Ride-On tire sealant. Balances and protects!
Posted 2015-01-06 5:16 AM (#169343 - in reply to #169338)
Weights. I've never had luck with the beads. You can still feel a unbalanced tire (depending on the severity) at 30 miles per hour or less.
Also; if you have to plug a tire with bead balancers installed; many of the beads are going to adhere to the stickiness of the plug; throwing it permanently off balance.
Edited by willtill 2015-01-06 5:17 AM
ByteN2it
Posted 2015-01-06 7:24 AM (#169344 - in reply to #169338)
+1 for Ride On. I've used the beads and they were fine-never an issue. The Ride On stays in place around the tire but is still viscous enough to move throughout the tires life and doesn't spill out like the beads when changing tires plus it can seal a puncture provided it's in the center strip of the tire.
http://www.ride-on.com/
Posted 2015-01-06 9:17 AM (#169345 - in reply to #169344)
ByteN2it - 2015-01-06 8:24 AM
Edited: Went to the Ride On site and answered my own questions.
Edited by willtill 2015-01-06 9:34 AM
Posted 2015-01-06 10:49 AM (#169346 - in reply to #169338)
work well. I've got them in my rear tire, weights on the front, both E3s, and I use Lucas 10w40 motorcycle oil. Everything rides smoooooooth.....
ljurgens
Posted 2015-01-06 10:54 AM (#169347 - in reply to #169346)
West Salem, WI United States
varyder - 2015-01-06 10:49 AM ...and I use Lucas 10w40 motorcycle oil...
You just had to spill oil on this thread
Edited by ljurgens 2015-01-06 10:54 AM
diamonbird
Posted 2015-01-06 12:40 PM (#169349 - in reply to #169347)
I tried the beads and than the Ride-On.........Ride-On wins!
The beads actually wear the inside of your tire and in doing so coat the beads, now I don't know if that hurts anything but they just aren't as good as Ride-On......
The beads are a.p.i.t.a to get though the valve stem even with a vibrating hand tool, Ride-On was a little messy but cleaned up easily. Ride-On wins!
luterdan
Posted 2015-01-06 1:30 PM (#169350 - in reply to #169338)
Marietta, GA
How about this instead? Buy once and you are done. http://centramatic.com/Page.aspx?page=Motorcycle-Balancers
Posted 2015-01-06 1:55 PM (#169351 - in reply to #169349)
diamonbird - 2015-01-06 1:40 PM
Ride On is expensive though... compared to wheel weights. Shoot... it would take 16 ounces of Ride On just to do my rear tire on my Rocket 3....
lstayner
Posted 2015-01-06 5:28 PM (#169353 - in reply to #169350)
luterdan - 2015-01-06 1:30 PM
+1 I have had a set now for 3 full sets of tires and they work fantastic. Some guys will chime in that they are expensive but when I traded my GW I sold them to another guy and they worked out about the same as the beads. Since I will most likely ride another Victory Vision, I will transfer them to the new bike in about 125,000 more miles.
Posted 2015-01-06 6:34 PM (#169354 - in reply to #169338)
Subject: RE: beads orwheelweights
gary1 - 2015-01-05 8:10 PM im close to putting new tires on just wandering how the dyna beads work any thoughts
You don't have to post this question 4 times.
el spanky
Posted 2015-01-06 7:25 PM (#169355 - in reply to #169338)
Victoria Tx, TX United States
Centramatics from Phatperformance
Turk
Posted 2015-01-07 6:55 AM (#169357 - in reply to #169338)
I tried Ride-on once, never again. That crap got all over the wheel and onto my friend's tire changing machine when he broke the bead to remove them. He made me clean up the wheels and machine, which I'll admit, was pretty easy, but still..... not a fan. And, before I took the tires to him, I did my own puncture test as per their video. The stuff just shot out the hole I made. Worthless.
At this point, the only dynamic device I would consider for balance would be the Centramatic system.
Edited by Turk 2015-01-07 6:56 AM
Posted 2015-01-07 8:21 AM (#169360 - in reply to #169338)
I wonder if that Ride On stuff actually would pool in the bottom of the tire; if you let your motorcycle sit for awhile; and if it was cold out; how long would it take to spin around inside of the tire so you wouldn't get an unbalanced effect.
Like I posted previously; it would take 16 ounces in my 240/55r16 Rocket 3 rear tire... that's a lot of damned misplaced weight if it pools up and thickens... losing viscosity due to cold weather.
okie vision
Posted 2015-01-07 8:11 PM (#169366 - in reply to #169357)
Broken Arrow, OK
Turk - 2015-01-07 6:55 AM
I'm with you. Both myself and another Vision rider used it, never again. It did NOT form a center mass like the website video shows. Nothing but a splatter mess everywhere when we dismounted both tires and absolutely would never seal a puncture. There's noway it provides proper balance. If you feel like it works in your tires, it's because they're balanced well enough to begin with.
Not a big bead fan either. When dismounting my tires using dynabeads, the beads are all black in a mass of rubber dust where they've eaten into the tire.
Back to regular weights.
