Poll Hitch Doc vs Bushtec Trailer Hitch
OptionResults
Hitch Doc Trailer Hitch
Other (please specify below)
Gerica
Posted 2011-01-12 6:20 PM (#77124)
Subject: Hitch Doc vs Bushtec Trailer Hitch
Hey All
I have researched online and on this forum regarding what people have been commenting on trailer hitches for both Hitch Doc and the Bushtec Hitch.... I am wondering if there are any more recent thoughts and opinions out there? Place a vote.... The "Poll" never lies.... LOL
Has anyone installed the Hitch Doc without removing the rear tire?
Tow capacities?
Where have people bought their Hitches online?
Is a swivel a good thing?
Thanks All
Edited by Gerica 2011-01-12 6:23 PM
Nepper
Posted 2011-01-12 6:36 PM (#77126 - in reply to #77124)
Subject: Re: Hitch Doc vs Bushtec Trailer Hitch
I have installed my Hitchdoc without removing the rear wheel and my trailer is fitted with a swivel because I have dropped my Vision before so I expect it may happen again and the swivel will prevent damage.
stevestreet
Posted 2011-01-12 7:25 PM (#77129 - in reply to #77124)
centrel Minnesota
I have also put on the hichdoc with out removing the rear wheel, but no swivel. got mine right through hichdoc.
lennyb
Posted 2011-01-12 8:41 PM (#77136 - in reply to #77124)
Perry Hall, MD
Hitchdoc - did not remove rear wheel - purchased through a forum member - no swivel installed - I am very satisfied (would note I am not pulling much weight like you might have with some of the campers, but would not anticipate any problems).
4speed
Posted 2011-01-12 9:28 PM (#77138 - in reply to #77124)
Regina Sask. Canada
Hi Hitch DOC and did not remove the rear tire and the trailer has a Swivel.
Gerica
Posted 2011-01-12 9:39 PM (#77139 - in reply to #77124)
Does anyone know tongue weights for these?
Baddog69
Posted 2011-01-12 10:26 PM (#77140 - in reply to #77124)
Billings, MT
I looked at both hitches. Bushtech's hitch seem to be built a little stronger. The Hitchdoc hitch seems okay but I didn't like the mount point system at all! I opted to spend about 25 hours and custom build my hitch receiver. It has a six point mount system, and is made of 1/4" plate steel. I am most impressed with the Vision's ability to tow a trail!
jomar
Posted 2012-07-03 9:07 AM (#118352 - in reply to #77140)
Hi all, I'm wondering what trailer wiring harness most of you are using for a 2011 Victory Vision? Thanks
Newfie
Posted 2012-07-03 9:09 PM (#118405 - in reply to #77124)
Edmonton, AB
I installed the Hitch Doc this spring on my 2008 VV. Yes, I did take off the rear wheel...but I'm a stickler for following directions and that just gave me an excuse to try taking the wheel off so I would be better prepared to do it when the need arises.
I purchased a no-name automotive style 5 to 4 wiring converter at a local Auto Parts store Tucked it away behind the tail lights after making the connections.
aaronrkelly
Posted 2012-07-04 4:16 AM (#118417 - in reply to #77124)
Moravia, IA
Hitch-doc......did not remove rear wheel, no need.
Install went very easy - no issues.
I pull several trailers, none with a swivel - havent found it necessary.
Im using a 5 to 4 converter from NAPA....cost $14 or so. I wire all my trailers 4 wire.....if they are 5 wire I convert them. I like them to be common so I can pull them with my truck or my bike.
jomar
Posted 2012-07-04 7:24 AM (#118422 - in reply to #118417)
I guess I should have been more specific with my question. Our new bike is the 2011 Vision, what wiring harnessdo you suggest and who is the manufacturer of it. does it need to be isolated and is there a place on the bike to plug it into directly or do you have to splice into it? Out trailer is a 4 wire.
aaronrkelly
Posted 2012-07-04 7:30 AM (#118424 - in reply to #77124)
Moravia, IA
There is no direct plug in wiring harness. There is no specific harness for this bike at all. Some run idolaters, some don't. I don't.....the 5 to 4 converter offers some protection and I'm good with that. Any 5 to 4 adapter will work....most use the Hoppy or NAPA.
texasgrumpy
Posted 2012-07-04 8:41 AM (#118435 - in reply to #77124)
I use the harness that came with my Bushtec which also had a 4/5 convertor option included. At first I had a buddies trailer that had a 4 wire set-up until I could find a used Bushtec trailer. Now that I have a Bushtec trailer I have switched over to a 5 wire set-up I love the pin hitch design especially for the Vision no binding if you get agressive on the curves.
witchbiker
Posted 2012-07-04 9:01 PM (#118492 - in reply to #77124)
Subject: RE: Hitch Doc vs Bushtec Trailer Hitch
3066 miles through MA, CT, NC, TN, VA,WV, PA, NY, VT, back to Maine with "Hitch Doc", pulling a 4' "Americas Best" aluminum trailer. No problems at all except for the tire quality of the trailer. 95% of trailer tire tread GONE after only 3066 miles?!?!? Will be sending Americas Best a little note soon!!
witchbiker
'08 Mid Cherry..hit 37k during trip...rear Dunlop cupping very badly. So bad, I'm concerned about being able to drive it safely to the dealer for a new tire.
BTW....Chrome IS a color!!
witchbiker
Posted 2012-07-04 9:04 PM (#118494 - in reply to #77124)
Hitch Doc is also a 6 point connection!!
wingit3611
Posted 2012-07-04 10:11 PM (#118497 - in reply to #77124)
I recently went to the June Boogie in Cookeville TN. Over The hill and thru the field up & down, and the hitch Doc took it without a problem. This is a very solid hitch. Going up the hills you couldn't slow down or you wouldn't make it up the hill, bounching up & down . Hitch Doctor took it with out a problem, the bike took it with out a problem, was very supprised, pulling BUNK hOUSE, which is not a lite trailer . This was ROUGH. Don't think you can go wrong with a Hitch Doctor.
wingit3611
Posted 2012-07-04 10:11 PM (#118498 - in reply to #77124)
