Fuel Door won't open
Kioti
Posted 2013-07-28 8:04 PM (#142174)
Subject: Fuel Door won't open
Lennox, SD
Went for a rife today and stopped for gas and fuel door will not open.
What is the trick to get it open now?
Am I headed for a teardown of the fairing?
Thanks in advance for your help
cw1115
Posted 2013-07-28 11:34 PM (#142180 - in reply to #142174)
Subject: Re: Fuel Door won't open
Ruskin, Fl
Happened to me hundreds of miles from home. I removed the radio at the gas station, pulled on the cable and the door opened. Then used tape to hold door shut rest of the trip. The plastic tab that holds the cable sheath had broken on my 2008. It is metal on my 2013.
I posted my repair with photos in tech reference.
Good luck. PM me if you need help and I'll send you my number.
cw1115
Posted 2013-07-28 11:38 PM (#142181 - in reply to #142174)
Ruskin, Fl
Kioti, I am just assuming that is you problem. Her it the link to my fix. The alternative was a new top tank piece that cost over 100 bucks.
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=12197&po...
donetracey
Posted 2013-07-29 12:27 AM (#142182 - in reply to #142174)
Pitt Meadows, BC Canada
Mine was done under warranty - it was deemed a poorly designed piece.
ByteN2it
Posted 2013-07-29 11:08 AM (#142196 - in reply to #142174)
Happened to me at my last fuel stop headed home from a week of touring-same thing the little clip that holds the cable broke. I could see the door moving slightly when I turned the key so I knew the cable was in tact-I was able to take a piece of stiff wire (like a coat hanger) and hook the cable through the gap at the hinge and pull on the cable while turning the key and got it opened and fueled up. I have since disabled the cable and latch spring and added magnets to keep the door closed-not terribly worried about fuel security, perhaps I'll fix the clip in the winter but it works for now.
XRsteve
Posted 2013-07-29 12:36 PM (#142201 - in reply to #142174)
Georgia, west of Atlanta
Magnets sound like a pretty good idea..........
Kioti
Posted 2013-07-29 7:02 PM (#142227 - in reply to #142174)
Lennox, SD
Thanks everyone for the replys, I got the door open thanks to ByteN2it.
I think I am going for the magnet idea to hold it closed until I get time to repair it
Posted 2013-07-29 7:07 PM (#142228 - in reply to #142227)
Kioti - 2013-07-29 7:02 PM Thanks everyone for the replys, I got the door open thanks to ByteN2it. I think I am going for the magnet idea to hold it closed until I get time to repair it
Good Luck never heard on magnets sticking to plastic and aluminum
Posted 2013-07-29 7:21 PM (#142231 - in reply to #142228)
johnnyvision - 2013-07-29 8:07 PM
A pair of magnets you Dork... one on the inside of the door and one on the fuel filler cap body part...
Lol!
ByteN2it
Posted 2013-07-29 7:35 PM (#142233 - in reply to #142228)
Magnets stick to other magnets. I used some strip magnets that peel & stick to pretty much anything-you can get 'em at a craft/hobby shop. Had to double 'em up to fill the gap and it takes a pretty good push to get them to release.
http://i69.photobucket.com/albums/i44/BRIANnCOLO/IMG_1531_zps5e2591...
http://i69.photobucket.com/albums/i44/BRIANnCOLO/IMG_1532_zpsb19b6d...
baadawg
Posted 2013-07-29 7:50 PM (#142235 - in reply to #142174)
Chattanooga, TN
That's using your noodle!
Posted 2013-07-30 7:25 PM (#142283 - in reply to #142231)
willtill - 2013-07-29 7:21 PM johnnyvision - 2013-07-29 8:07 PM
A pair of magnets you Dork... one on the inside of the door and one on the fuel filler cap body part... Lol!
THANKS FOR THE NAME CALLING
jeffmack
Posted 2013-07-31 8:17 AM (#142300 - in reply to #142174)
Johnny, have u seen your numerous posts??? I'm surprised he didn't call u worse than dork
Kioti
Posted 2013-09-27 6:51 AM (#145982 - in reply to #142174)
Lennox, SD
I contacted the new dealer in my area to get my fuel door repaired since I have the extended warranty.
Reply from Polaris star(warranty company) was not what I expected.
They denied the claim the dealer filed because the warranty CLEARLY STATES that it DOES NOT COVER COSMETIC BODY PANELS.
I guess the poor design of the fuel door cable retaining system is JUST LIKE the poor design of the front fender. Must be a wear item?
At this point I am very disappointed in Polaris and Victory
diamonbird
Posted 2013-09-27 6:57 PM (#145991 - in reply to #142174)
The last people on my list to call when I have a problem with my Victory's is Victory! No since in getting pissed off twice!
BrandonM7
Posted 2013-09-28 8:32 PM (#146023 - in reply to #142300)
LaGrange, GA
jeffmack - 2013-07-31 9:17 AM
rotflmao
Man314
Posted 2013-09-29 6:22 PM (#146042 - in reply to #142174)
Had mine break off on a road trip 400 miles from home. Thank God I had my tools and a tube of JB Weld
