Rear Shock Air Adjustment
Crawford
Posted 2008-02-15 12:35 PM (#5304)
Subject: Rear Shock Air Adjustment
Regina Saskatchewan Canada
Has anyone played around with the rear shock air pressure to see how it affects the ride and handling? Have you came to any conclusions about ideal pressures for various load weights? Are you using the Victory or Progressive's hand air pump or something else?
VisionTex
Posted 2008-02-15 2:04 PM (#5310 - in reply to #5304)
Subject: RE: Rear Shock Air Adjustment
LaPorte,Tx.
When I ride alone, I have basically no to very little up to 5 psi on the shock. Gives a very good ride, does not wallow in the curves, and does not bottom out. I weigh in around 200, plus a little weight in the trunk and bags.
When I ride two up, I put about 20 - 26 psi on the shock. Ride & handling are good and does not bottom out. I can't, and won't say what the wife weighs, I just don't go there.
The ideal pressure, I don't know........I have the Victory pump.
Big Vic
Posted 2008-02-15 5:15 PM (#5318 - in reply to #5304)
Subject: Re: Rear Shock Air Adjustment
Southeast Iowa
I have the Victory pump and use their settings. So far so good. I really need more seat time before I know if these are "ideal" or not.
sandman
Posted 2008-02-15 6:12 PM (#5323 - in reply to #5304)
rhode island
there are recommened air pressures near the air valve, i weigh 220 and air up to 38p.s.i with two up 60p.s.i ride is firm but still very compliant keeping some air the shock should help the air bladder from cracking from non use. i use the victory pump also. high pressure air pumps could damage the bladder
metalguy
Posted 2008-02-18 11:05 PM (#5456 - in reply to #5304)
Tacoma, WA
I finally got smart and adjusted mine for two-up riding. It was only at 20#! My girl and I were bottoming out over larger bumps, and I was getting the high-beam flash from other motorists WAY too often. Now, at 50# it is all good!
cjnoho
Posted 2008-02-19 2:07 AM (#5459 - in reply to #5304)
So Cal
I keep mine at 30 psi. have only bottomed out twice. Still wasnt as bad as the HD.
BUCKEYE
Posted 2008-02-19 6:43 AM (#5473 - in reply to #5304)
29 Palms California
uh? cjnoho, your bragging again? I've never bottomed out.
pollolittle
Posted 2008-02-19 12:00 PM (#5486 - in reply to #5304)
Brighton, TN
Like cjnoho, I too bottom out will have to adjust position, oh I mean pressure, no air. I have been leaving mine at no air. Guess I need to go back and look at it again.
cjnoho
Posted 2008-02-19 10:57 PM (#5512 - in reply to #5304)
So Cal
When I first got the bike I couldnt believe how well it took all the dips and bumps without any problem at 35mph. Now that I'm more comfortable, I'm hitting some of them at 45-50. I'm curious if another 10 psi will help or hinder?
CoolHandLuke
Posted 2008-02-25 7:33 PM (#5830 - in reply to #5304)
, FL United States
I run mine @ 50# for 2up riding (which is most of the time). When I go out solo, I don't bother to reset it.
BTW the other day I rode after a rain shower. While accelerating up an Interstate 95 on-ramp, the Vis got a little "squirrelly" when I shifted into 2nd. I let off the throttle quickly & she settled down nicely. This bike has ssooooooooo much power that it raises my "pucker factor" from time to time when I get down hard on the throttle. Still learning to ride
lowtone9
Posted 2008-03-05 10:45 PM (#6345 - in reply to #5304)
The bottom is a myth, it doesn`t exist.
Crawford
Posted 2008-03-05 10:53 PM (#6347 - in reply to #6345)
lowtone9 - 2008-03-05 9:45 PM
Eh??
or
Huh?? if you prefer . . .
cjnoho
Posted 2008-03-05 11:48 PM (#6349 - in reply to #5304)
So Cal
i have been playing with the pressure a little. 25 solo (200lbs.), above that rear feels a little squirrely. Two up plus wifes stuff, 30-35, gives a nice smooth ride. Rides better two up.
Crawford
Posted 2008-03-06 9:47 AM (#6358 - in reply to #6349)
cjnoho - 2008-03-05 10:48 PM
Try 10 - 15 solo.
maddog
Posted 2008-03-06 1:20 PM (#6368 - in reply to #5304)
Nebraska
I have been adjusting it when I ride 2up vs one up. I really like the feel of it lower when Im 1 up. An electric pump would be a real nice feature. I wouldnt think it would be hard to do.
cjnoho
Posted 2008-03-06 11:29 PM (#6414 - in reply to #6358)
So Cal
15 is even better, I'll try 10 tomorrow. Thanks.
