LED Accent lighting
kin52
Posted 2015-04-17 7:44 AM (#171916)
Subject: LED Accent lighting
Louisville, KY
Who has leds on their bike and what to you like or dislike about the led kit you bought?
Any suggestions to what you would do differently?
Pictures would be great.
kin52
Posted 2015-04-17 11:38 AM (#171919 - in reply to #171916)
Subject: RE: LED Accent lighting
Louisville, KY
I guess I should clarify looking to add some leds to the engine area and wheels.
jdr00ejr
Posted 2015-04-17 12:09 PM (#171921 - in reply to #171916)
Subject: Re: LED Accent lighting
Indianapolis, IN United States
I'm struggling to justify the cost - but leaning heavily toward these:
http://vic-litez.com/products/copy-of-basic-kit-01
kin52
Posted 2015-04-17 2:46 PM (#171923 - in reply to #171921)
Louisville, KY
I'm kind of leaning towards a kit that will light up the motor and wheels and maybe the ground around the bike a little. the kits are around 250 bucks.
jdstamp
Posted 2015-04-18 4:48 PM (#171949 - in reply to #171916)
Trenton, Ohio
Here are a couple of pics of the led's around my engine.
(image.jpg)
(image.jpg)
Attachments image.jpg (55KB - 0 downloads)
Attachments image.jpg (67KB - 0 downloads)
Posted 2015-04-18 7:29 PM (#171953 - in reply to #171916)
i used to have LEDS on past bikes.. but i really dont ride alot when its dark enough for anyone to even see them..
icemann
Posted 2015-04-19 2:23 AM (#171964 - in reply to #171916)
, OH
you can save a ton of money doing it your self. You can get a roll of water proof led cut to length, peel and stick or zip tie for $20.00
(led%20rings.jpg)
Attachments led%20rings.jpg (46KB - 2 downloads)
icemann
Posted 2015-04-19 2:27 AM (#171965 - in reply to #171916)
, OH
example only. $3.99 each roll. http://www.aliexpress.com/item/5m-RGB-Led-Strip-3528-Non-Waterproof...
Wharf_rat
Posted 2016-04-10 11:20 AM (#181893 - in reply to #171916)
Republic of Texas
These are alternating colors
Edited by Wharf_rat 2016-04-10 11:23 AM
j.wales
Posted 2016-04-11 4:22 AM (#181905 - in reply to #171916)
Asheville, NC
I'm considering a small amount of LED accent lighting. If I do it won't be as extensive as the example above. I intend to put the fourth switch into the console to control them once I decide which color and where to mount them.
Bear13
Posted 2016-04-11 8:03 AM (#181908 - in reply to #171916)
I got the Opti7 kit off of Amazon.
http://www.amazon.com/3-into-1-Motorcycle-Multi-Color-Accent-Cruise...
Pro's:
- good price
- the kit came with lots of lengths of connectors and y-cables, I even had several left over
- Multi color
- intensity control
- steady on, flash, fade modes
- two remotes in the kit
Cons:
- get yourself additional 3M adhesion promoter. The kit comes with one, but it will dry before you get very thing stuck.
http://www.amazon.com/3M-Adhesion-Promoter-Sponge-Applicator/dp/B01...
- I would advise also wiping surfaces to be taped with alcohol as an additional step to ensure adhesion.
- (subjective) I added some aluminum angle pieces under the saddle bags to avoid light bleed between the bags and exhaust. Just extra work.
Edited by Bear13 2016-04-11 8:09 AM
(1111111.jpg)
(222222.jpg)
Attachments 1111111.jpg (67KB - 0 downloads)
Attachments 222222.jpg (18KB - 0 downloads)
j.wales
Posted 2016-04-11 6:19 PM (#181914 - in reply to #171916)
Asheville, NC
Nice set up Bear13, thanks for the link. Thx for the tips from your experiences. How is the power consumption rate if they're on fade and the bike is off ? Battery killer ?
Edited by j.wales 2016-04-11 6:23 PM
Bear13
Posted 2016-04-11 8:27 PM (#181922 - in reply to #171916)
I haven't had them long enough yet to judge battery drain... I just installed them last month.
jdr00ejr
Posted 2016-04-12 7:27 AM (#181936 - in reply to #181908)
Bear13 - 2016-04-11 9:03 AM
Pro's:
- good price
- Multi color
- intensity control
Cons:
Bought the same kit for the Wife's Can Am Spyder. Haven't started the install process yet though.
On my Vision, I have the Vic-Litez Cheese Wedges in Red which I love! I have Victory Logo Puddle Lights up front. Just added a TricLED Knight Rider LED Stripe to my trunk as well. I've done the EBay cheap Waterproof LED Stripes all the way around the bottom of my trailer. Installed the 4710 Mod to turn my trunk lights into Brake/Signal Lights.
Guess it's time I get started on the Can Am.
Bashcars
Posted 2016-04-14 12:48 PM (#182152 - in reply to #171916)
Katy, TX United States
I bought my LED kit from www.joeflorida.com. Very happy with the setup. I would do a few things different, but still love the way it looks.
TEXAS ALLERT: Texas passed a new law that went into effect 1/1/2016. Any accent lights on the bike have to be white or yellow when ridding on the road. I have multi-colored lights with many options. I have run other colors since 1/1/16 and have not gotten pulled over yet. But now you have been informed.
(photo 4.jpg)
(photo 1.jpg)
(photo 2.jpg)
(photo 3.jpg)
Attachments photo 4.jpg (69KB - 0 downloads)
Attachments photo 1.jpg (76KB - 2 downloads)
Attachments photo 2.jpg (72KB - 2 downloads)
Attachments photo 3.jpg (74KB - 0 downloads)
Posted 2016-05-05 7:59 PM (#182930 - in reply to #171916)
correct me if i am wrong.. but isnt the idea behind these LED kits or what not is to NOT see the actual leds?
