HMD Skid Plate Bolts Rusting
Street Eagle
Posted 2013-05-24 8:41 PM (#139493)
Subject: HMD Skid Plate Bolts Rusting
Manchester, CT
Fellow Riders
I installed a HMD Skid Plate on my 2013 Vision and the bolts are rusting after only 300 miles. If you have the HMD product installed are the bolts rusting. I contacted them and they feel it is not an issue since they haven't had any complaints from anyone else. They suggested that I purchased stainless bolts versus trying to make things right.
Thanks!
Banjodan
Posted 2013-05-24 9:06 PM (#139495 - in reply to #139493)
Subject: Re: HMD Skid Plate Bolts Rusting
like any other product....there are ways to improve it. you prob. have many bolts under your vision rusting. or will..
Edited by Banjodan 2013-05-24 9:07 PM
Banjodan
Posted 2013-05-24 9:09 PM (#139496 - in reply to #139493)
hey street eagle.... does that flip wind screen do a better job than factory?
Street Eagle
Posted 2013-05-24 9:25 PM (#139497 - in reply to #139493)
Manchester, CT
Hey Banjodan...i only have 300 miles on the plate and i checked, these are the only things rusting.
Its been raining since I've installed the windshield. Hoping to get it out tomorrow. I will let you know what I find out about the flip.
Posted 2013-05-24 10:06 PM (#139502 - in reply to #139493)
You may have better luck contacting Arlen Ness since they make the product. HMD only sells them.
Rollin'
Posted 2013-05-24 10:34 PM (#139503 - in reply to #139493)
, WI
Ness stopped making the skid plate over a year ago. Someone else is making them.
I have had my Ness skid plate for over a year including the ride on the salt covered Dalton Highway and have no rust on the mounting bolts.
Monkeyman
Posted 2013-05-25 6:58 AM (#139510 - in reply to #139493)
Peru, IN
I thought the skid plate used the stock bolts? Why would they rust if they weren't rusting before the install. Or do you have to drill new holes?
Rollin'
Posted 2013-05-25 7:12 AM (#139511 - in reply to #139493)
, WI
No drilling. Comes with new longer bolts.
Monkeyman
Posted 2013-05-25 9:35 AM (#139515 - in reply to #139493)
Peru, IN
No kidding? I wonder if Witchdoctors comes with longer bolts (vid doesn't show longer bolts). Anybody know what the difference is between the 2?
If the bolts are rusting, could you just buy new stainless steel bolts? Would SS be too brittle, especially for the floorboard mounts? (Or is the HMD version even bolted at the floorboards?)
Bad Horsie
Posted 2013-05-25 10:35 AM (#139517 - in reply to #139493)
Subject: RE: HMD Skid Plate Bolts Rusting
Alberta
You don't want to put stainless steel into aluminim as it will start a galvanic corrosion site. If you do insert SS into Al you need to use a nickle based thread lube, don't use a copper based thread lube
Monkeyman
Posted 2013-05-25 11:46 AM (#139520 - in reply to #139493)
Peru, IN
Well, of course you'd have galveston corruption stuff. Nothing like using nickles and lube instead of copper.
All (poor) humor aside, I had no idea things would be that involved. I wonder why those bolts are rusting. SE lives on the east coast. Maybe it's a salt air thing?
Street Eagle
Posted 2013-05-25 1:31 PM (#139522 - in reply to #139493)
Manchester, CT
Thanks guys....is there another alternative to stainless that I might use.
I have to tell you I am not impressed with HMD's lack of customer support and support of their product. Not sure if I could stay in business if I sold a product, it has an obvious issue and I told my customer to go out and purchase something else that might work.
okie vision
Posted 2013-05-25 3:02 PM (#139524 - in reply to #139493)
Broken Arrow, OK
take a small paint brush and coat them w/ Testors model black enamel paint. Get a little bottle at a hobby store
Travelin Man
Posted 2013-05-26 7:45 AM (#139533 - in reply to #139493)
Um, HMD is a forum member here, did you contact him directly or only speak to someone at his business?
As far as galvanic corrosion, that process will occur with ANY steel mated to aluminum, not just stainless steel, so in that case I would replace the supplied bolts with high strength stainless steel bolt, or as Okie stated, take some enamel paint and paint the bolt heads if they bother you that much. Me, I would simply ride the crap out of it first!
MaddMAx2u
Posted 2013-05-26 9:53 AM (#139537 - in reply to #139533)
Orlando, FL
Travelin Man - 2013-05-26 8:45 AM
+1 Sooner or later you'll have rust elsewhere. Ride that bitch!
Street Eagle
Posted 2013-05-26 12:00 PM (#139540 - in reply to #139493)
Manchester, CT
Yes, Mike from HMD I add did communicate via email and I first spoke with him when he didn't ship the bolts with the plate.
