Stuck throttle
Turk
Posted 2011-09-26 9:00 AM (#97708)
Subject: Stuck throttle
This has happened to me several times now in the last week. Cruising along, with the cruise control either powered on (but NOT set) or off, and the throttle sticks.... I either discover it when I left off the throttle and speed doesn't decrease, or when I go to shift gears and the engine bounces off of the rev limiter when I pull the clutch in. Also happened once in a parking lot when I was letting someone hear my exhaust by blipping the throttle (gently). It started bouncing off the rev limiter then too, and the cruise was not activated!
The momentary cure is to blip the throttle a couple times and it comes unstuck. I can't tell if this is a mechanical sticking problem, or an electronic one. It almost feels electronic though....
Has anyone else experienced this?
Tarpits99
Posted 2011-09-26 9:19 AM (#97709 - in reply to #97708)
Subject: Re: Stuck throttle
North Orange County CA
http://www.Vision-riders.com/bb/forums/thread-view.asp?tid=4937&pos...
e+cable+lock+nuts&highlightmode=1&action=search#M50085
Check your bike per the issue presented in this thread.
glighto11
Posted 2011-09-26 10:11 AM (#97714 - in reply to #97708)
Central New York
Again with the posting of problems with no information. What are we talking about, a 2001 F150 with 160k miles?
Posted 2011-09-26 10:32 AM (#97720 - in reply to #97708)
I'm going to be risky and take a guess he is talking about a victory vision ....
Posted 2011-09-26 10:59 AM (#97727 - in reply to #97708)
Here is the perfect example of what we should have where we live and what year and model bike we have posted in our profile.
#1 have you changed grips?
#2 have you changed cables of the bike?
#3 what have you messed with that you aren't telling us?
Find your manual and read about cable adjustment and then check your bike. It might be your return cable is out of adjustment
Turk
Posted 2011-09-26 11:22 AM (#97734 - in reply to #97720)
Arkainzeye - 2011-09-26 10:32 AM
Good guess. It was in my signature, which seems to oddly be missing now... hmm
Edited by Turk 2011-09-26 11:23 AM
Turk
Posted 2011-09-26 11:26 AM (#97736 - in reply to #97734)
It was in my signature, but apparently the option to "use my signature" was turned off..... funny... cuz it was on previously....
Yes, I had already gotten a tip from kevinx to check the locknuts on the cable at the t-body attachment point. I do remember reading that thread when it was first posted, but thought it was on a different forum. Will be doing that when I get off work.
Edited by Turk 2011-09-26 11:29 AM
Turk
Posted 2011-09-26 12:39 PM (#97742 - in reply to #97736)
That was it, the nut had backed off the threads of the throttle sleeve. Little bit of blue locktite and tightened her down. Should hold for a while.
RedRider
Posted 2011-09-26 1:11 PM (#97749 - in reply to #97708)
It was listed under "Vision Tech Q&A" Heading. Not clear enough I guess? Here's your sign....
Let me beat the reply, "No year."
Turk
Posted 2011-09-26 1:50 PM (#97757 - in reply to #97749)
RedRider - 2011-09-26 1:11 PM
Thanks, your reply was quite helpful and constructive...... guess you didn't read the post where I acknowledged that I conducted my search on the wrong forum initially.... you'll need your sign back.
Edited by Turk 2011-09-26 2:09 PM
Tarpits99
Posted 2011-09-26 2:28 PM (#97767 - in reply to #97708)
Turk
Glad that the problem was easily corrected before something truly ugly happened.
Everyone who hasn't already done so should check that lock-nut. Ounces of prevention and all that.
victoryvisiontour
Posted 2011-09-26 4:19 PM (#97783 - in reply to #97708)
Subject: RE: Stuck throttle
I fixed mine after reading the original thread a while back. After reading this thread, I am going to check it again tonight to make sure everything is still good.
KansasGuardsman
Posted 2011-09-26 5:01 PM (#97788 - in reply to #97708)
Wichita, Kansas
I've had a similar thing, but my throttle just got sticky. The mounting nuts were fine. It happened 3 or 4 times. My throttle just got really tight and 'sticky'. I couldn't find a problem and since I knew about it I rode it. Twice it just suddenly started working normally about 15 minutes into the ride. Once it came home that way, after over an hour, but was cleared the next ride. Once it cleared after only a couple of minutes. The only common factor was temps were below 40 each time. I thought some thing got into the throttle cable but it has not happened again and that was almost 2 years ago, with many equally cold rides.
Posted 2011-09-26 5:18 PM (#97791 - in reply to #97708)
Everyone seeing this read the post at the link below. Then go and inspect your Vision.
It only takes a minute and you should do it every week .......maybe once and a while on a long ride.
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=4937&sta...
Ride Safe
