0W40 Oil - Yes another oil thread ---->
Cap'n Nemo
Posted 2011-01-29 1:38 PM (#78362)
Subject: 0W40 Oil - Yes another oil thread ---->
New Bohemia, Va
I've used 10w40 for the most of the life of my Vision and it was worked as expected, regardless of brand, so long as it was JASO: MA. I've had the start up tick-tick-tick basically from the beginning, especially if I started the bike on the kick. During this past summer I ran a 20w50 for the hard desert riding and then switched back to the 10w40 on return. I heard folk talk of the 5w40 oil and decided to give that a try and was very pleased since it made the start up tick-tick-tick nearly non-existant.
Well today I went to my old oil jobber and he only has the 10w40 or 20w50 motorcycle oil and I quipped I wish he had 5w40. His reply was he had no 5w40 but he did carry a 0w40 with a JASO: MA rating. He only had one quart on hand so I ask him to order me enough to change my oil. I figure if 5w40 worked well to greatly reduce the tick-tick-tick the 0w40 should eliminate it. He'll get this week and I probably change my oil next weekend, weather permitting. I'll let you folk know how it turns out in case you might want to give it a try.
Thar she blows....!
handyhiker
Posted 2011-01-29 1:54 PM (#78365 - in reply to #78362)
Subject: Re: 0W40 Oil - Yes another oil thread ---->
Akron, Ohio
I use the synthetic 5w-40 Turbo Diesel oil from Mobil. No tick at start up and easy to find at auto parts stores. I used this in the bike I had before the Vision as well and it made a huge difference in the transmission shifting. Really smooth. I talked my brother into trying it as he always used the motorcycle specific oils, and the first thing he did was punch me in the arm. He said that the transmission shifted so quiet and smooth in his old Star 1300 that he had trouble telling if he really shifted or not. He ran it till he got rid of the bike. He is now a believer.
donetracey
Posted 2011-01-29 2:01 PM (#78367 - in reply to #78362)
Pitt Meadows, BC Canada
Lemon Oil with Pine Scent .... sMMooothest shifting!
Biscuit
Posted 2011-01-29 6:15 PM (#78372 - in reply to #78367)
Midlothian, Va.
donetracey - 2011-01-29 3:01 PM Lemon Oil with Pine Scent .... sMMooothest shifting!Does Amsoil make that?
hoosiervic
Posted 2011-01-29 7:16 PM (#78376 - in reply to #78362)
Subject: RE: 0W40 Oil - Yes another oil thread ---->
Indianapolis, IN
Cap'n Nemo - 2011-01-29 2:38 PM I've used 10w40 for the most of the life of my Vision and it was worked as expected, regardless of brand, so long as it was JASO: MA. I've had the start up tick-tick-tick basically from the beginning, especially if I started the bike on the kick. During this past summer I ran a 20w50 for the hard desert riding and then switched back to the 10w40 on return. I heard folk talk of the 5w40 oil and decided to give that a try and was very pleased since it made the start up tick-tick-tick nearly non-existant. Well today I went to my old oil jobber and he only has the 10w40 or 20w50 motorcycle oil and I quipped I wish he had 5w40. His reply was he had no 5w40 but he did carry a 0w40 with a JASO: MA rating. He only had one quart on hand so I ask him to order me enough to change my oil. I figure if 5w40 worked well to greatly reduce the tick-tick-tick the 0w40 should eliminate it. He'll get this week and I probably change my oil next weekend, weather permitting. I'll let you folk know how it turns out in case you might want to give it a try. Thar she blows....!
I attached the following link to a previous oil question, probably much to the dismay of some. I will attach below again for those with the will or desire to read due to cabin fever or whatever. This guy has a very logical approach to the science of oil and lubrication in general. I would recommend starting with the articles starting on the home page called "Motor oil 101". Enjoy if you are interested!
http://www.bobistheoilguy.com/cms/index.php?option=com_content&view=frontpage&Itemid=1
Cap'n Nemo
Posted 2011-01-29 7:52 PM (#78378 - in reply to #78362)
New Bohemia, Va
thanks, I've read the oil guy, great forum for oil. I'm not concerned in using this oil, just mentioning it in case someone had tried or thought on trying but was scared to use it. I'm not expecting any problems.
Posted 2011-01-29 8:24 PM (#78379 - in reply to #78362)
Just one thing to say
(oil change.jpg)
Attachments oil change.jpg (52KB - 0 downloads)
hoosiervic
Posted 2011-01-29 9:05 PM (#78383 - in reply to #78378)
Indianapolis, IN
I would agree. What I take from the Oil Guy's explanations and reasoning is that we all tend to try to solve oil related problems by doing the opposite of what we should do. By this I mean we tend to conclude wrongly that heavier viscosities are more beneficial under "harsh conditions". He clearly reasons that lighter viscosities, particularly as relating to the first number in the multi-viscosity oils, produces more complete lubrication at start up than do heavier oils.
As he points out in a number of places, we have known widely for years that most engine wear occurs during the critical time the engine is running with cold oil upon start up. And he also shows that upon reaching operating temps there is very little difference in actual viscosity between the different oil weights we generally use compared to that of the lighter oils. Now there are limitations here, particularley for continuous desert heat conditions, or say for those that only ride long distances and rarely make short jaunts around town.
On the other hand if you only ride 15 minutes or less at a time for the most part, say daily commutes to work, the oil never truly reaches operating temps. This could have a major effect on engine wear over time if you prefer using heavier oils such as 20w50 or more.
One last thing that would benefit all of us is the effect of viscosity on fuel mileage. By running oils on the heavier end of the scale we experience much higher levels of hydraulic drag and therefore decrease mileage significantly. Conversely with lighter viscosity oils mileage is significantly increased. Many couldn't care less about the above info. That's fine, but for those that do, it can make a big difference in overall durability and long term cost savings.
BTW another side benefit is that with lighter viscosity oils the starter and battery system don't work nearly as hard to crank over and start the engine. This could add significantly to the overall life of these components as well.
Cap'n Nemo
Posted 2011-01-29 9:17 PM (#78386 - in reply to #78362)
New Bohemia, Va
Very well put hoosiervic and that confirms that fits what I do. Being a daily rider, averaging 75 miles a day year round, I do pay attention to the oil. The positive thing that I've learned is I wont' kill my engine just because I use another oil that what came in it. Also, I figured roaring down the highway in desert heat for 3 weeks I thought better to change to the 20w50 oil. When I returned to the cooler tempatures the bike sounded like it would come apart. These V-Twin motors, I mean engines are fickled to say the least on ambient tempature. The 0w40 oil, I don't recall, ever has been discussed on here, but I'm willing to take a plunge on my sword for it. It is advertised for ATV to include Polaris, but it carries a MA rating for wet clutch, so what the hey...
Cap'n Nemo
Posted 2011-02-12 5:08 PM (#79181 - in reply to #78386)
New Bohemia, Va
Done
wrr1home
Posted 2011-02-12 7:31 PM (#79185 - in reply to #79181)
Chris,
I did use the 0W-40 last year during this colder months and never had a problem with it. The startup ticking was gone and shifting was smooth. As the weather warmed back up, I went back to the 10W-40 and had no problems. Amsoil all the way!
Cap'n Nemo
Posted 2011-02-12 7:45 PM (#79187 - in reply to #78362)
New Bohemia, Va
I'm going to see what happens in the morning, but I was pleased it sounded like it was already running warm when I fired it up after changing the oil. We'll have an overnight of 26 degrees, so that'll be a good test.
Posted 2011-02-13 1:06 PM (#79230 - in reply to #78362)
hoosiervic Great the way you said every thing. I just read the oil guys out look on oil and defiantly changed my thinking.
Thicker is not better.
I like how he said oil looses its quality when stored in cold garages and come spring get rid of the old oil in your bike and in your car.
Like others have said before let your motor warm up and never rev your motor when cold. Yes it doesn't matter if its a car a bike or a lawn more
