New Radio and Gas Tank on 08
rlreed
Posted 2008-12-12 9:14 PM (#24961)
Subject: New Radio and Gas Tank on 08
Tavares, Fl
Victory finally agreed to replace both my radio and gas tank. I'm happy now, or at least I will be once its done....
wjoel
Posted 2008-12-12 9:43 PM (#24962 - in reply to #24961)
Subject: RE: New Radio and Gas Tank on 08
Northeastern Penna.
What happened to your radio that it was replaced, I'm assuming under warranty, right?
rlreed
Posted 2008-12-12 9:52 PM (#24964 - in reply to #24962)
Subject: Re: New Radio and Gas Tank on 08
Tavares, Fl
Yes under warranty, lack of reception, while adjusting volumn the channel changed also.
ScoreBo
Posted 2008-12-12 11:14 PM (#24967 - in reply to #24961)
Northeast Ohio
Poor reception is normal. Were you changing the volume with the handle bar controls or on the radio?
rlreed
Posted 2008-12-13 8:31 PM (#25003 - in reply to #24961)
Tavares, Fl
The handle bar volumn control also changed the channel. I bought an am/fm splitter from Sierra electronics and installed it in the CB antenna line and still had poor reception so it wasn't the antenna
Wizard523
Posted 2008-12-13 8:47 PM (#25005 - in reply to #24961)
Woodland Hills, CA
I too am getting my radio changed under warranty (along with the computer), if it ever arrives from Victory. I've only been waiting for about 2 months now! I hope you have better luck.
rlreed
Posted 2008-12-13 8:51 PM (#25007 - in reply to #24961)
Tavares, Fl
The dealer said it should be in next week along with the gas tank....As long as I get it I'll be happy, I'm in Ohio right now and the bike is in Florida so I can't ride anyhow....
Teach
Posted 2008-12-13 8:55 PM (#25008 - in reply to #24961)
I'd be willing to bet thereception won't be much better on the new radio but I'll keep my fingers crossed for you. What was wrong with your fuel tank????
Did the dealer already install the NEW style handlebar control for the channel switching issue? If not you better have them order that as well.
rlreed
Posted 2008-12-13 9:40 PM (#25012 - in reply to #24961)
Tavares, Fl
I couldn't fill the gas tank or gas would splash out while riding, at times I had gas splash out on my right leg while riding. The neck had a visible gouge in it and a depression that would not seal with the gas cap. I expected a fight because the dealer claimed I bent the neck. I argued that I have owned many cars and trucks, street rods and motorcycles and this is the first filler neck I've ever seen bent so they agreed to replace it. I really think the early gas tanks were made of some soft metal. The dealer didn't say anything about ordering the handlebar control. I'll check when I get back down. I may get the antenna mentioned in the other threads and install it if the reception doesn't improve. I seldom listen while I'm riding, I'd rather hear the humm of the engine and the wind rushing by but I keep it on for the better half as she likes to listen. I really wish they would install controls for the passanger. I really enjoy the bike but I was getting frustated dealing with trying to get it fixed. In Ohio the local dealer went out of business and the closest decent dealer was a two hour drive.
coachwes
Posted 2008-12-13 10:39 PM (#25015 - in reply to #24961)
savannah ga
when i asked my dealer about the radio bar control messing up and the radio going to aux when starting up .He said there is a reprogram update on it .I havent heard about this here yet , has any body heard about this update for the radio fix .I heard of replacing the bar controls .Unless the aux problem is fixed with the reprograming and he figured it would fix both. As far as reseption its ok not great but it works ok picks up the stations around me but i havent really whent for a long ride yet to test range. glad to hear they will replace yours thow reed
Posted 2008-12-13 11:12 PM (#25017 - in reply to #24961)
coachwes,
Check out the following post about a radio re-flash I just received.
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=2435
rlreed
Posted 2008-12-14 9:22 AM (#25029 - in reply to #24961)
Tavares, Fl
I read that earlier, after the new one is installed I'll be sure and check the version....I really don't expect much out of the radio, I think Victory took a royal screwing from the manufacturer of the radio system, but what can they say they supposedly took three years to develop the bike they should have caught this one. I don't listen to it much, usually when I get tired of the engine noise I'll turn the volumn up but the better half likes to listen to talk radio, one thing I cannot stand, makes my blood pressure go up. I'll eventually download some music to an ipod and use it....
Posted 2008-12-14 8:51 PM (#25056 - in reply to #24961)
The Amplified antenna helps a lot for the FM radio reception problems.
Since I have had it flashed. I had reset the Bass Treble and Fader settings from default 0. As stated on Vision-Riders before, turn up the Bass and Treble to +6 (the max). Now that it is set the same as before the flash update, I have noticed that it sounds better then before the flash when using the iPod. The lower mids sound better. AC/DC Back in Black sounds great now.
FYI I have stock speakers. I wonder if the 09's really have better speakers or just a better program in the radios DSP chip?
Ride Safe
