Lloyds Top intake
jjp53
Posted 2013-01-13 8:14 PM (#129517)
Subject: Lloyds Top intake
Gilroy, Ca
When you install Lloyds top intake on the vision with stock exhaust do you you need to retune the bike
Monkeyman
Posted 2013-01-14 1:41 AM (#129525 - in reply to #129517)
Subject: Re: Lloyds Top intake
Peru, IN
Probably. If you get more air in AND more air out, you'll run lean without either a reflash or a fuel processor. Since the Visions stock exhaust already lets alot of air out, that doesn't fit in the equation. Now that you're adding a lot more air, it'll run lean (which is a bad thing). I've heard of some who just unplugged their O2 sensors but I wouldn't do that for long (if at all). VFC from WD is less than $300.
c10jm
Posted 2013-01-14 6:32 AM (#129526 - in reply to #129525)
I put the thrush mufflers on my vision and my pipes have a lot soot on them . This bike seems like to me it runs pretty rich . If that is the case a little lean wouldn't hurt . Am i wrong ? My bike is an 09 and my buddies is an 11 and his are the same as mine .
Liandra
Posted 2013-01-14 6:58 AM (#129527 - in reply to #129526)
Tifton, GA
I got mine flashed after I put the thrush mufflers on mine to go with the top plate I had added earlier. My mileage came back to where it had been before the additions and I like the extra power. Hope to do cams in the spring My pipes still have a lot of soot and only ran the bike a few hundred miles before the flash.
Monkeyman
Posted 2013-01-14 9:24 AM (#129532 - in reply to #129517)
Peru, IN
My '12 is still bone stock and I get quite a bit of soot. Must be another reason other than running rich.
kevinx
Posted 2013-01-14 4:16 PM (#129539 - in reply to #129517)
Sooting comes mostly from cold operation, and hard running
jjp53
Posted 2013-01-14 10:24 PM (#129566 - in reply to #129517)
Gilroy, Ca
So do I have to retune my bike if I add the top filter?
Monkeyman
Posted 2013-01-15 12:11 AM (#129575 - in reply to #129539)
Peru, IN
kevinx - 2013-01-14 5:16 PM
And that answers my question perfectly. I bought the bike in the middle of Sept so there have been very few riding days I would consider "warm" so far. Once it was broken in, I started getting a little hard on the throttle. (Kinda like a drag racer would feel. All that power.)
Vicbuilder
Posted 2013-01-15 5:37 AM (#129578 - in reply to #129566)
The Vic Shop - Central Iowa
jjp53 - 2013-01-14 10:24 PM
NO.
jjp53
Posted 2013-01-15 7:12 AM (#129582 - in reply to #129517)
Gilroy, Ca
Thanks Rylan
Are you doing any cam installs in northern California any time soon?
GeddyLee
Posted 2013-01-19 9:39 PM (#129805 - in reply to #129582)
jjp53 - 2013-01-16 5:12 AM
Thanks Rylan
I would love to know the answer to this question! From oneNor Cal Victory man to another...
Vicbuilder
Posted 2013-01-20 8:03 AM (#129816 - in reply to #129517)
Subject: RE: Lloyds Top intake
All that is required to get a cam party going is 3 or more bikes. When you guys have 3 or more bikes wanting cams then call me and I'll book the flight. Easy as that
jjp53
Posted 2013-01-20 8:33 AM (#129818 - in reply to #129517)
Gilroy, Ca
Well you have one guy for sure
