Bad Belt at 56,000/Michelin Primacy HP Rear
etspastimes
Posted 2010-10-10 9:37 AM (#71352)
Subject: Bad Belt at 56,000/Michelin Primacy HP Rear
Salisbury, NC
Last week I started to change out my rear tire. While I had it off, I noticed the belt had a hole in it. Since I had a new belt in waiting, it would not be a big deal. After looking at the rear sprocket , I knew I needed to replace that also. Whatever punched a hole in the belt had also chipped a couple of teeth. Thanks to Victory replacing so many rear sprockets because of the belt squeak, I picked up a almost new one for the price of shipping. The belt was not to bad as far as replacing it. With the tire already out from under it, I only had to remove the right side muffler and rear tip-over. I didn't have to mess with taking the pipes loose from the heads because there was enough room to take the bolts out of the front sprocket cover and slide the belt past it. Bolted everything back together and finished replacing the rear tire, it was good to go. I will say that having new tires makes the ride great again. With the Michelin Primacy having rounded shoulders, I have a better feel of the road compared to the Kumho that was on it. Most of the comments from the tire shop were good about the wear of the Kumho being that it was on a bike. They said that it looked like it was on a car. ET
http://imageevent.com/etspastimes/rosiescartireinstalled?rotp=4044&n=0
The link above has pictures of the Kumho and the Michelin.
Edited by etspastimes 2010-10-10 9:44 AM
Posted 2010-10-10 1:42 PM (#71358 - in reply to #71352)
Subject: Re: Bad Belt at 56,000/Michelin Primacy HP Rear
How many miles did you get out of the old car tire? I can remember back about 30 years ago we built bikes with car tires cause we wanted a big back tire. We found a tire store that would cut the edges so it was a little more round. They use to cut tires cause they were not very round back in the day. With rounded edges we could corner a little bit better.
I am scared to run a car tire cause I really lean into corners maybe to much.
On a harley once I like you picked up a rock and poked it out and road another 10,000 miles before winter when I replaced it. I even road with Arlen Ness who had picked up a rock and split the belt. I don't know how many miles road it that way buy he didn't care it just looked cool. Might know he would come out looking good.
Posted 2010-10-10 2:52 PM (#71361 - in reply to #71352)
Thanks ed for the write up. where did you get your sproket from? I need one...
Tarpits99
Posted 2010-10-10 3:07 PM (#71364 - in reply to #71352)
North Orange County CA
http://cgi.ebay.com/ebaymotors/2008-VICTORY-POLARIS-V100-V-100-VISI...
pt=Motorcycles_Parts_Accessories&hash=item3a5efcce8f#ht_3353wt_804
one on ebay right now
Posted 2010-10-10 3:19 PM (#71366 - in reply to #71352)
...thanks TP99, it says used, I was hoping to shoot for something new. I am encouraged with the used price though and it may be worth scarfing it up. Mine is shot...
Tarpits99
Posted 2010-10-10 4:06 PM (#71367 - in reply to #71352)
Looks like the bike is being parted out. You might ask the seller how many miles were on the bike. Then again it is an 08, it may be a squealer.
Posted 2010-10-10 4:19 PM (#71368 - in reply to #71352)
...I have an '08 but it was never a "squealer" like some were, but it did growl...
etspastimes
Posted 2010-10-10 5:58 PM (#71372 - in reply to #71352)
Salisbury, NC
Try Mike down at Victory of Cumming. The one he sent me looked almost new. And no squeals for now. As far as the last tire, it took 26,000 to wear it out. ET
Edited by etspastimes 2010-10-10 6:00 PM
rf43mn
Posted 2010-10-10 6:42 PM (#71375 - in reply to #71352)
Subject: RE: Bad Belt at 56,000/Michelin Primacy HP Rear
Willmar, MN
Just curious what you have your bike up on in pic 22? It doesn't look like anything I've seen before.
Posted 2010-10-10 9:09 PM (#71382 - in reply to #71375)
rf43mn - 2010-10-10 7:42 PM
tell us more...
kevinx
Posted 2010-10-11 6:29 AM (#71392 - in reply to #71382)
varyder - 2010-10-10 10:09 PM
tell us more...
Looks like a set of sport bike lever jacks
etspastimes
Posted 2010-10-11 6:38 AM (#71394 - in reply to #71352)
Salisbury, NC
It is a small lift that is rated at 1200 pounds. What you can't see are the straps that I ran from the tip-overs to the hoist hooked to the rafters. ET
